This kit integrating a volume controller and a display is a solid base for the development of your DIY projects. This product consists of two plug-in modules with a 6-pin connector that can be easily separated for easy integration.
PGA2311
Delivered as standard without remote control, it can be controlled with an RC5 remote control.
Volume control | PGA2311 : -95dB to +31dB by 1dB step |
Power supply | AC +/- 8 to 12V |
Stereo input / output | On 3 poles XHP connectors |
Rotary encoder | 6mm axis |
IR Remote control | Included |
Main module | Display + encoder : 100 x 32mm |
Secondary module | 85 x 32mm |
Holes spacing | 26 x 78mm |
