AIYIMA T8 Tube Preamplifier 6N3 Headphone Amplifier MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz
With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier stage uses a 6N3 tube, which gives a nice musicality with a warm and round sound. The headphone amplifier on its side is based on the integration of a MAX9722 chip allowing it to offer a power of 120mW under 32Ω.
Reference : 16145
139,00 €tax incl.
115,83 € tax excl.
Shipping date: 15-11-2024.
Aiyima T8
Aiyima T8 Préamplificateur à Tube 6N3 Amplificateur Casque MAX9722 DAC ES9018K2M
With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier stage uses a 6N3 tube, which gives a nice musicality with a warm and round sound. The headphone amplifier on its side is based on the integration of a MAX9722 chip allowing it to offer a power of 120mW under 32Ω. Finally, the digital section of the device takes advantage of an ES9018K2M DAC and a CM6642 interface, allowing the support of sampling rates up to 24bit 96kHz and ensuring an accurate audio reproduction.
In terms of connectivity, the T8 is not to be outdone and will easily fit into the vast majority of audio systems. There are stereo RCA, Toslink Optical, Coaxial, USB-B and even a Bluetooth 5.0 wireless reception supporting the high definition codecs aptX and aptX HD. For the outputs, we will be able to count on stereo RCA in line output and Jack 6.35mm in headphone output.
Moreover, the design of the Aiyima T8 was thought to accompany and integrate perfectly with the Aiyima A8 amplifier.
The Aiyima A8 amplifier is sold separately.
Product typePreamplifier
Headphone amplifier
DAC
InputsBluetooth 5.0
1x Stereo RCA
1x Optical Toslink
1x USB-B
1x Coaxial
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
Tube6N3
OPAOPA1656
Headphone amplifierMAX9722
USB InterfaceCM6642
DAC ChipES9018K2M
Bluetooth receiverQCC3031
Supported Bluetooth codecsaptX
aptX HD
Supported sampling ratesPCM up to 24bit 96kHz
DistortionRCA : 0.2%
Headphone amplifier : 0.003%
SNRRCA : 108dB
Headphone amplifier : 106dB
Compatible headphone impedances16-300Ω
Max output powerRCA : 1.9V
Headphone amplifier : 120mW @ 32Ω
Input sensitivity2V
Frequency response20Hz-20kHz (±0.5dB)
Supply voltage12VDC (Power supply supplied)
Dimensions138 x 123 x 51mm
Weight550g
OutputJack 6.35mm
DAC / ADC ChipES9018K2M
Max sampling rate96kHz
ClassTube amp
Remote ControlYes
3 reviews
Perfect , but ...
It's really awesome preamp / dac . I use it in my P sistem - Dac Aiyima T8 and straight to my power amp Emotiva BasX A300 . Everything is beautiful, sound is excellent , but be aware that the output RCA is weak , like 1.9 V. So if you want more volume you really have to crank it up to allmost max volume from Dac . Except this thing, the preamp is really really good sounding and works like a charm
This review has been posted for AIYIMA T8 Tube Preamplifier 6N3 Headphone Amplifier MAX9722 DAC ES9018K2M Bluetooth 5.0 24bit 96kHz
Excellent
Fait très bien le Job. Excellent.
Sound and functionality very good fast delivery and good packed
With the T8, Aiyima offers a versatile device that is a tube preamplifier, headphone amplifier and DAC at a very affordable price. Its preamplifier...
