AUDIOPHONICS PRE-02 NJW1194 Preamplifier Volume Control Input Selector Bluetooth 5.0
The Audiophonics NJW1194 preamplifier is an extremely versatile device at a more than affordable price. If it is first presented as a preamplifier, it also offers volume control and input selector features, with additional Bluetooth 5.0 support.
4.0 / 5
Reference : 15528
99,00 €tax incl.
82,50 € tax excl.
Audiophonics PGA2310 Préamplificateur Contrôle de Volume Sélecteur de Source RCA Bluetooth 5.0
An excellent volume controller
As its name suggests, the device incorporates a volume control based on a NJW1194 TI chip offering very good audio performance. This allows a very precise volume adjustment from -96 to 0dB. This chip allows to obtain a very low distortion of 0.004%, a dynamic range of 117B, a THD+N of 0.001% at 1kHz and a crosstalk of -120dBFS.
Connectic
The Audiophonics NJW1194 offers both classic connectivity with 4x stereo RCA inputs but adds Bluetooth in version 5.0, thanks to its JL AC1820AP chip. It is thus possible to stream your music remotely from a device with this connectivity such as a smartphone or tablet for example. Bluetooth version 5.0 ensures excellent stability and transmission speed for quality listening. A Bluetooth antenna is included to improve transmission.
The output side is simply one stereo RCA to connect the NJW1194 to an amplifier.
The unit's power supply circuit incorporates efficient multi-channel regulation to significantly reduce noise.
Audiophonics PGA2310 Connectique
Power circuit
The quality of the power supply being decisive in the quality of the sound reproduction of an audio system, the Audiophonics NJW1194 benefits from a neat circuit. Thus, it integrates an efficient multi-cana regulation allowing to limit considerably the noise as well as an EMI / RFI filter allowing to filter the interferences which could generate noise.
Audiophonics PGA2310 Filtre EMI / RFI
Simple but effective design
In terms of design and ergonomics, the Audiophonics NJW1194 is simple and efficient. The components are integrated in a robust brushed aluminium housing with the most beautiful effect. A 51 x 20mm front panel screen displays both the active source from the 4 available and the sound volume, the latter up to an absolute value of 100. The white LED display provides excellent readability for easy adjustments. The unit also comes with an infrared remote control, allowing access to all settings, including volume adjustment, mute mode and source selection.
Audiophonics PGA2310 télécommande et écran
The IR receptor is very sensitive to directionnality. The remote will not work if the transmitter angle is too wide.
Power cable sold separately.
Product typePreamplifier
Volume control
Input selector
ChipNJW1194
Distortion0.001%
Dynamic range117dB
THD+N0.0015% (2Vrms)
Crosstalk-120dB
InputsBluetooth 5.0
4x Stereo RCA
Output1x Stereo RCA
Output impedance215 ohm
DisplayRed LED display, 51 x 20mm
Bluetooth chipBTM308
HousingBrushed Aluminium
Supply voltage230V AC
Total dimensions (With antenna + volume button)Approx. 196 x 130 x 48mm
Value / Volume-90dB à 0dB
Weight820g
ColorSilver
Power cableNot included (available as accessories)
Package1x Audiophonics NJW1194
1x IR Remote Control (CR2032 batteries not included)
ColorSilver
ClassN/A
Remote ControlYes
4 reviews
nice
everything is fine, happy I am, except for the missing remote battery and alimentation cable.
bluetooth name (of my device at least) is QCC3008
remote is a leTV one ? black, small, clean,with a label wrote in corean I think, its fine by me :)
This review has been posted for AUDIOPHONICS PRE-02 NJW1194 Preamplifier Volume Control Input Selector Bluetooth 5.0
Ce à quoi l on s attendait
Rapport qualité prix excellent, fait bien son job avec un bon son.
Le BT est très correct.
Seul bémol livré sans cordon d alimentation ni pile dans la telecommande
Specs not quite right
The specs are misleading, because this is not a dual mono design, and the chip datasheet clearly shows that crosstalk of -120db is at low frequencies, but rises steeply at high frequencies. This could have likely corrected with a dual mono design. Otherwise sound is very transparent.
Basses et aigus réglables
Ne l'oubliez pas !
How to enter the tone adjustment mode method:
- Press and hold the Volume button. the display“Treble” will twinkle.
- Then rotate the volume button to adjust the Treble +/ -10dB range.
- Press one time again the Volume button. the display“Bass” will twinkle. Then rotate the volume button to adjust the BASS +/ -10dB range.
The Audiophonics NJW1194 preamplifier is an extremely versatile device at a more than affordable price. If it is first presented as a preamplifier,...
