Balanced Preamplifier RCA XLR 10x NE5534D 4x NE5532D ALPS Potentiometer with Remote Control
This symmetrical preamplifier offers an excellent design quality based on circuits recognized for their performance and the quality of their sound reproduction. It integrates on its stage no less than 4 AOP NE5532D and 10 AOP NE5534D mounted on DIP8 support and therefore easily modifiable to adapt the sound signature of the preamplifier.
4.7 / 5
By buying this product you get 44 loyalty points
Reference : 14308
449,00 €tax incl.
374,17 € tax excl.
Préamplificateur
Symétrique RCA XLR 10x NE5534D 4x NE5532D Potentiomètre ALPS avec Télécommande
Préamplificateur Symétrique RCA XLR 10x NE5534D 4x NE5532D Potentiomètre ALPS avec Télécommande
This symmetrical preamplifier offers an excellent design quality based on circuits recognized for their performance and the quality of their sound reproduction. It integrates on its stage no less than 4 AOP NE5532D and 10 AOP NE5534D mounted on DIP8 support and therefore easily modifiable to adapt the sound signature of the preamplifier. The volume control uses a motorized potentiometer ALPS 907M-100KBX4 allowing an attenuation of the clean signal.
The power supply stage is not to be outdone since it includes an EMI/RFI filter, 5 voltage regulators and 2 filtering capacitors Nover Audio Grade 10000µF 50VDC. This architecture provides all circuits with a stable and noiseless power supply.
On the connector side, there is a series of 4 unbalanced stereo RCA inputs and one balanced stereo XLR input, as well as one unbalanced stereo RCA output and one balanced stereo XLR output. The preamplifier comes with a remote control for convenient remote control including power on/off, source selection and volume level management.
The preamplifier components are housed in a sturdy, plain black brushed aluminium case, which can be easily integrated into any HiFi system.
Product typePreamplifier
Inputs4x Stereo RCA
1x Balanced stereo XLR
Outputs1x Stereo RCA
AOP10x NE5534D
4x NE5532D
Motorized potentiometerALPS 907M-100KBX4
SNR110dB
Remote Control(AAA 1.5V batteries sold separately)
Gainx6
Power supply (power cable not included)AC220V
Case materialAluminium
Dimensions (WxDxH)431 x 255 x 63mm
Weight3.8kg
Power cableNot included (Available as an accessory)
InputXLR
ClassN/A
Remote ControlYes
6 reviews
Ok. Has drawbacks.
+ Audio quality.
+ Quality built.
+ Swappable opamps.
- Device gets rather hot (after a while), on the outside, no ventilation openings, inside temperature probably very high. Should be taken in account when stacking devices.
- Remote volume(-) is sometimes interpreted as volume(+) on the edge of its range (~5m).
- Remote control "Next" of my Onkyo C-S5VL SACD is also interpreted as "Next audio channel" by the device. No other matching codes.
- Volume control motor makes a lot of noise. A full rotation to zero is performed at startup, even when it is at zero already. (Nnngggjjj...)
- Volume is reset at absolute zero at startup. Requires getting used to.
- Volume knob has no visible position-indication.
- Documentation ?
This review has been posted for Balanced Preamplifier RCA XLR 10x NE5534D 4x NE5532D ALPS Potentiometer with Remote Control
Rapport Q/P hors norme
Je rejoins les précédents avis.
Un produit étonnant en termes de rendu sonore et de finition au regard de son prix plus que démocratique.
La perfection sera atteinte avec un meilleur contrôle qualité en fin de chaîne de fabrication (une résistance a été oubliée sur mon exemplaire mais vite corrigée par Audiophonics)
Un appareil hors du commun
L'appareil est en fonction depuis une semaine, et mes explorations sonores avec lui ne sont pas encore terminées. Choisi sur le conseil de David Aubert, arrivé sans encombre, très bien emballé. Ce préampli est anonyme, mais on peut assez facilement retrouver son origine sur certain site chinois, où il est présenté comme un clone (sonore ? car l'apparence ce n'est pas ça du tout) du monstrueux préampli allemand MBL6010D. Le design du préampli est peu commun, avec ses touches en alu (?) munies en leur centre de led bleues, et avec ses pieds dorés (faute de goût à mes yeux, mais pardonnable et aisément masquable). La machine donne une rassurante impression de solidité. Télécommande en plastique, un peu cheap. Le tout sans aucun mode d'emploi, ce qui est un peu déroutant mais n'est pas un obstacle, tellement l'utilisation coule de source. Aucun problème pour l'installation, entre un DAC SMSL SU-9 et un ampli MPA-S125NC XLR stéréo classe D NCore alimentant des Q Acoustics 3030i (chaîne de bureau). Pour mettre en route, il faut actionner l'interrupteur arrière, ce qui fait clignoter discrètement le bouton Power sur la face avant. Ne reste plus qu'à choisir sa source en appuyant sur une des cinq touches à disposition (ou en se servant de la télécommande). L'action enclenche des relais, dont on entend les clics très francs en même temps que s'allument les leds de la touche Power et de la touche source choisie. Il faut dès alors actionner le gros bouton de volume (ou la télécommande) pour atteindre le niveau sonore désiré.
Et là c'est un vrai plaisir ! La qualité sonore est au rendez-vous : délié, détail, fruité des cordes, fermeté des graves, scène sonore large et profonde, le... pied ! Et je pense que ça va encore un peu s'affiner avec le temps. Mais ça ne pardonne pas pour les mauvais enregistrements.
Attention : à l'extinction, le volume se remet à zéro tout seul (ce qu'on a tendance à oublier lors de l'utilisation suivante, car le bouton ne revient pas à sa position précédente, qui n'est pas mise en mémoire, apparemment).
Les fonctions de la télécommande sont basiques : ouverture/mise en veille, choix des sources, mute, volume + ou -.
En bref , les moins : anonymat (vite démasqué), design un poil baroque, absence totale de documentation. Les plus : qualité de la construction, facilité d'utilisation, qualité sonore exceptionnelle, et... le prix !
A true gem
I must admit I was sceptical at first. A first rate preamp at this price. But now I'm a convert. This piece of kit is excellent. All the way down to the construction. It sounds amazing, beating out a lot of preamps that I have in my possession many times the price of this unit. With better soundstage, clarity and separation. The only caveat is that the gain might be a little hot for some amps. Many thanks to David at Audiophonics customer service.
Unbalanced and Balanced Preamplifier
The quality of a professional device for just over € 300, I really don't know how it pays off for the manufacturer! Nothing is missed by chance, multiple stabilized power supply with audio graded electrolytic capacitors, printed circuit board from edge to edge of the chassis, no wires, anti-oxidation coating, premium JRC AOP with the possibility of easy replacement according to taste on stabbing sockets, low noise metal oxide resistors , aluminum housing circa 5 mm thick, and all for a little over € 300! Wow! Congratulations to the manufacturer!
This symmetrical preamplifier offers an excellent design quality based on circuits recognized for their performance and the quality of their sound...
