FX-AUDIO DP-02 Tube Preamplifer 6K4 / Files player USB SD / Bluetooth
The DP-02 from FX-Audio is a compact, complete and unbeatable value for money device with a wide range of features. Its dimensions allow it to be easily and discreetly positioned on a desk.
4.6 / 5
Reference : 13394
69,90 €tax incl.
58,25 € tax excl.
DP-02
Tube preamplifier, headphone amp, file player
FX audio DP02
The DP-02 FX-in Audio is a compact, complete with an attractive price given the wide range of features offered. Its dimensions allow it to be positioned easily on any desk.
It is able to play files stored on USB / SD card or sent via Bluetooth, make a D / A conversion, pre-amplify the analog signal and control the volume. In short, once in place, the only thing it needs is power amplifier or an active speaker to rmake a full audio system.
The DP-02 also features a 3.5mm headphone jack and can be controlled remotely thanks to a included remote control.
File Player
https://www.audiophonics.fr/img/cms/Images/Produits/13K/13394/DP-02_Main_sq.jpg
The DP-02 is a file player. That is to say that it is able to function as an audio source from digital audio files. The device is able to decode all formats of the ordinary general music: MP3 (320Kbps max), WMA (384Kbps max) and APE, FLAC (of 44.kHz / 16-bit 48.kHz / 24-bit) and WAV (of 44.kHz / 16-bit 96.kHz / 24-bit).
The source / file playing is highly intuitive to handle since the DP02 has a female USB-A input and an SD card reader. As long as you have any of such devices, you will be alble to easily transfer large data of audio files to the player.
Playback settings (play / pause / stop / next track / previous track) are accessibes from the front of the unit. A supplied remote control also offers the possibility to remotely control the DP02.
Warning, the DP-02 is not a file explorer, so it does not support the concept of folders and cannot organize your audio files.
Tube preamplifier
Tube headphone amplifier
After decoding the audio files, the signal is pre-amplified through two tubes mounted on the top of the device.
The tubes in question are vacuum tubes 6K4 model. They contribute to a warm and lively sound reproduction. The construction of the DP-02 ideally accommodates this preamp tubes stage and manages to offer a 1.9Vrms output level with a 0.2% THD and S / N ratio of 88dB. Amazing specifications for a device of this size and in this price range.
connectivity
DP02 FXAUDIO outputs
With the exception of the SD card and USB-A inputs which are positioned on the front for easy access. The rest of the connection is on the back of the housing. From left to right, a connector for Bluetooth antenna (supplied), a line input and a 3.5mm stereo RCA input.
As output, the DP-02 has a stereo RCA output and a 3.5mm headphone jack port.
Finally, the rear panel also has a DC input jack for powering the device through the included AC adapter.
Controlling the device
All device control options are available on the front panel. A remote control is also provided to let the user control the DP-02 from distance.
This comprehensive remote control provides access to all the features offered. It can be used to change the source (RCA / Aux), change volume, skip to the next track / previous or even program the repetition of the currently playing track.
The parameters for Bluetooth (including pairing) are also accessible via this remote control.
Compact dimensions
The DP 02 has extremely compact dimensions: height 3.4cm x width13cm x length 11 cm, the DP02 FX-home audio can be integrated easily, enven into rooms lacking space.
TypePreamplifier
file Player
headphone amplifier
source selector
Classlamps
lamp model6K4
THD0.2%
Output Level1.9Vrms
SNR88dB
Frequency response20Hz-20kHz
power headphone output17MW
Headphone Output THD0.2%
Headphone output SNR83dB
Frequency response headphone20Hz-20kHz
inputsBluetooth, USB, SD Card
OutputsRCA / 3.5mm
Bluetooth version4.0 ACTS
Dimensions130 x 110 x 34mm
FoodJack DC 12V 1A
Weight420g
Parts supplied
DP-02x1
Remote controlx1
AC adapterx1
InputJack 3.5mm
OutputJack 3.5mm
9 reviews
Appareil de qualité
Bonne qualité audio avec les lampes d'origine.
Il me permet d'adapter la sortie d'un vidéoprojecteur à l'entrée d'un ampli. Il est juste dommage qu'il ne mémorise pas sa dernière configuration. I démarre systématiquement en mode bluetooth.
This review has been posted for FX-AUDIO DP-02 Tube Preamplifer 6K4 / Files player USB SD / Bluetooth
Très bon appareil sauf que...:-)
Sauf qu'un mode d'emploi - si possible en FR ne serait pas inutile, par ex. pour comprendre la fonction EQ. Performances d'ensemble positives mais la connection casque aurait été mieux à l'avant. Beau look mais un peu petit quand même. Télécommande impeccable.
Essai en salle de ventes
https://youtu.be/wd8X0BbhrvY
Excellent
Après une erreur suite à la lecture d’un forum que le site a géré très professionnellement, j’ai reçu ce produit qui est un condensé de ce qu’un quinquagénaire non frappé d’illectronisme et amateur de musique pouvait espérer.
Ce produit devrait faire partie des « produits de première nécessité »
Quelques gros défauts
Appareil sympathique, avec toutefois 2 gros défauts :
- un défaut de masse erratique, même raccordé à un ampli de puissance. Disparaît puis revient.
- il faut l'allumer et l'éteindre avec l'ampli raccordé sur off, sinon bruit affreux et danger pour les hp.
The DP-02 from FX-Audio is a compact, complete and unbeatable value for money device with a wide range of features. Its dimensions allow it to be...
