FX-AUDIO FX98S PRO Preamplifier / Headphone amplifier DAC PCM2704 Black
Here is one of the brand new FX-Audio products, the FX98S PRO! An ultra polyvent device, because it performs the functions of a preamplifier, headset amplifier and USB DAC on its own.
Reference : 12592
57,90 €tax incl.
48,25 € tax excl.
FX-AUDIO FX98S PRO
Preamplifier / Headphone amplifier / DAC USB / Black
FX98S PRO Black Fx-audio
This FX98S acts as a clever little preamplifier for a small desktop amplifier or HiFi installation lacking punch. Featuring a gold-plated stereo RCA stereo input and output, it will be a quality companion coupled with a Class D power amplifier to restore dynamics and sound to any missing installation.
You've also offered a 6.35mm jack headphone output, allowing you to listen to your favorite music on the headphones, thanks to its MAX9722 amplifier chip. And to fill the gap, this FX98SPRO offers a USB-B digital input upstream of a PCM2704 DAC, allowing you to decode sample rates up to 24Bit / 48kHz.
This preamplifier does not have the caricatural sound impastoed in the lower midrange of classic preamplifier productions. On the contrary, the terms transparency, dynamics, musical unbridled, sound matter are the ones that immediately come to mind when listening to this FX-Audio FX98S PRO.
An excellent introduction to the subject for any enthusiast who wants a quality, affordable, quality preamplifier/headphone amplifier.
Stereo headphone amplifierMAX9722
DACPCM2704
Output power100mW
Impedance16 - 32Ω
Frequency response20Hz to 20kHz
Signal/Noise ratio85dB
THD0,15%
USB Sampling Rate24bit / 48kHz
BBE Sound EnhancementLow Boost and High Boost: 15dB max
SRS (3D stereo)SRS1 : NJRC Original Simulated Surround
SRS2 : 3D-Stereo - High Mode
SRS3 : 3D-Stereo - Low Mode
Connectivity
InputsGold plated RCA / 3.5mm Jack / USB-B
OutputsGold plated RCA / 6.35mm Jack
Power supply formatJack DC 5.5/2.5mm (compatible 5.5/2.1mm)
Dimensions132 x 82 x 30mm
Weight400g
AccessoriesAC adapter 220V to 12V DC 1A / USB-B to USB-A cable
InputJack 3.5mm
OutputJack 6.35mm
Here is one of the brand new FX-Audio products, the FX98S PRO! An ultra polyvent device, because it performs the functions of a preamplifier,...
