FX-AUDIO TUBE-03 Valves 6K4 Stereo Preamplifier Black
FX-AUDIO TUBE-03 Valves 6J1 Stereo Preamplifier Black
Introducing the all-new 6J1 FX-Audio TUBE-03 tube buffer preamplifier. The latter now offers bass and treble tuning accessible from the front.
4.6 / 5
Reference : 12400
38,90 €tax incl.
32,42 € tax excl.
Shipping date: 23-07-2024.
FX-AUDIO TUBE-03
Tubes preamplifier 6K4 Stereo Black
fx-audio tube-03 préamplificateur à tubes
Introducing the all-new 6K4 FX-Audio TUBE-03 tube buffer preamplifier. The latter now offers bass and treble controls accessible from the front.
This TUBE-03 acts as a clever little tool to improve the sound of a desktop DAC or HiFi installation lacking punch. With a gold-plated stereo RCA stereo input and output, it will be a quality companion coupled with a class D power amplifier to restore dynamics and sound to any missing installation.
At the proposed price, this device has qualities usually absent in this category.
Moreover, this preamplifier does not have the caricatural sound impastoed in the lower midrange of classical tube productions. On the contrary, the terms transparency, dynamics, musical untiedness, sound matter are the ones that immediately come to mind.
An entry level excellence for any enthusiast who wants an affordable tube preamplifier of high quality.
Output power2000mW
Impedance600Ω
Frequency response20Hz to 20kHz
SNR100dB
Input sensitivity300mV-2000mV
Gain Max : 6dB
Output level Max : 2.7V RMS
Compatible tubesEF95
6AK5
6J1
Connectors
InputsGold plated RCA
OutputsGold plated RCA
Power supply connector formatJack DC 5.5/2.5mm (5.5/2.1mm compatible)
Dimensions100 x 95 x 32mm
Weight480g
AccessoriesPower supply adapter 220V to 12V DC 1A
ClassTube amp
23 reviews
BIZARRERIES APRES UN CERTAIN TEMPS D'UTILISATION...
L'enthousiasme suscité par ce petit préampli lors des premières utilisations a laissé place aujourd'hui à des doutes, en effet mes deux lampes neuves Jan 5654 se sont brutalement dégradées après seulement deux mois d'utilisation (à raison d'une heure de musique par jour), l'aigu est devenu hyper acide, insupportable, et le médium maigre, sans saveur. Je se sais pas si c'est le préampli qui a détérioré prématurément les tubes et je n'en écarte pas la possibilité car le niveau de sortie de cet FX-Audio Tube 03 est quand même très élevé (trop?). En remplaçant les tubes par des 6J1 (ceux d'origine) la restitution n'est pas vraiment bonne avec un aigu certes doux mais un grave manquant sérieusement de définition et de transparence. Bref je suis revenu à une liaison directe DAC-Ampli.
This review has been posted for FX-AUDIO TUBE-03 Valves 6K4 Stereo Preamplifier Black
bien mais...
j'ai commandé ce petit appareil pour avoir la possibilité de calmer un peu la partie médium de mon ensemble, c'est mieux en diminuant un peu les aigus mais il ne faut pas trop baisser au risque de perdre trop, un réglage pour les médium aurait été plus pertinent et j'ai vu trop tard que ça existait. concernant les lampes je n'ai pas remarqué un son plus chaud qu'avant, après un moment de chauffe par contre la scène sonore s'élargie un peu plus et c'est très bien, le rendu est plus doux. suite à ce que j'avais lu, j'ai laissé allumé une journée, résultat je ne le referai pas, je pensais qu'une fois une certaine température était atteinte l'écoute serait stabilisée ben j'ai trouvé le son encore plus agressif comme si l'appareil ne faisait plus effet, résultat je le coupe en même temps que le reste et ça va mieux. je pense que je testerai les autres tubes. j'ai fait une comparaison sur mon installation avec un autre modèle sans lampes mais avec réglage médium en plus, une catastrophe, medium utile mais même en laissant les boutons sur midi les voix étaient trop en retrait et son étouffé et en activant le bypass quelle claque, le son est redevenu vivant et les voix présentes. j'ai rebranché mon fx audio et c'est bien mieux quand même. les réglages aigus sont bien calibrés, mettre au milieu pour démarrer, le volume est bien aussi calibré pas de mauvaise surprise ( inséré entre un préampli Atoll pr200 et un ampli 3Dlab Nano ) surtout ne pas oublier l'ordre de la mise en route, à l'allumage fx audio en premier et ensuite le reste, et à la fin de l'écoute éteindre tous les appareils en premier et le fx audio en dernier sinon gros bruit dans les enceintes ( et ça fait peur ) .
j'avais une panne de mon préampli de "moyenne gamme" (environ 800€) et voulais aussi bien /mieux
j'ai demandé conseil et j'avais des doutes "pas assez cher"
résultat vraiment surprenant et heureux , ne pas hésiter , j 'utilise une alimentation IFI audio ,aussi sur les conseils de David Aubert
prenez avis auprès d'Audiophonics
BOÏTE MAGIQUE...
Après quelques jours d'utilisation intensive du petit FX-AUDIO Tube 03 je me permets de donner un avis supplémentaire pour enrichir celui que j'ai déjà donné et reflétant les premières heures d'utilisation. Il faut reconnaître qu'une fois les tubes rodés ainsi que le petit buffer lui-même, la restitution devient bluffante de qualité. Les timbres sont extrêmement agréables avec une richesse harmonique rare, On ne note aucune acidité sur les violons, ce petit buffer sera à même de corriger beaucoup d'amplificateurs à transistors un peu trop brillants. La dynamique est également de premier ordre et l'image stéréo assez spacieuse selon les tubes choisis. Un petit buffer vraiment exceptionnel.
RESTITUTION ASSEZ TYPEE...
Pour le prix d'une poignée de main dans une boutique Hifi High-End vous avez ici un petit préampli susceptible de procurer de réels plaisirs aux amateurs du son typé "tube". Je ne saurais trop conseiller d'effectuer un" tube rolling" afin de trouver ce qui conviendra à vos goûts car les tubes 6K4 fournis d'origine ont tendance à émousser l'aigu alors que les 5654W se révèlent nettement plus équilibrés. De même, bien que moins important, on peut changer les ampli ops. Les LM 4562 NA à très faible bruit ne conviennent pas, rendant l'aigu trop brillant voire acide, les JRC 5532 procurent un résultat très honorable et les TLE2142CP confèrent un peu plus d'aération, adoptés ! Il faut reconnaître tout de même que ce préampli favorise le médium, ce que les inconditionnels du tube apprécieront mais les puristes un peu moins, en effet les musiciens sont placés au premier plan ce qui génère beaucoup de présence mais défavorise la profondeur d'image, ce que personnellement je regrette. Comparé à l'ampli classe D Aiyima A07 MAX (seul), ce dernier possède une image plus spacieuse, c'est incontestable, et un grave d'une meilleure tenue. Ceci dit ce petit FX-AUDIO Tube 03 ne démérite pas; je suis étonné par sa très bonne transparence et sa fidélité de timbre, chose d'autant plus étonnante que l'alim fournie (12V, 1A) n'est pas de type faible bruit. Faut-il y voir une conception du répartiteur interne d'alimentation particulièrement soignée ou bien l'effet des lampes elles-mêmes, tout simplement ? Autre élément à porter au crédit du FX-Audio: sa dynamique, sa spontanéité qui rend la musique particulièrement vivante. En conclusion : un préampli au son assez typé qui réjouira ceux qui aiment ce genre de sonorité, personnellement je reste fidèle aux bons amplis classe D directement attaqués par un DAC pour leur restitution proche du signal et leur réalisme affirmé.
P.S. Mention spéciale "tableau d'honneur" pour le S.A.V. d'Audiophonics qui m'a remplacé un tube défaillant avec une réactivité exemplaire, aussi je recommande chaudement l'enseigne Audiophonics, certes vous pourrez trouver très légèrement moins cher sur un certain site marchand basé en Chine, mais soyez bien conscient qu'Audiophonics vous procure écoute, conseils, garantie et service après vente "first rate", choses que vous ne trouverez pas ailleurs.
