HATTOR AUDIO THE BIG Unbalanced Passive Preamplifier Vishay SMD Brown
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier and selectors of 5 sources and 4 outputs, this device with its aluminium and wood finish will convince. It is equipped with very high quality components assembled by hand with the greatest care.
By buying this product you get 94 loyalty points
Reference : 10708
949,00 €tax incl.
790,83 € tax excl.
Shipping date: 31-01-2025.
HATTOR AUDIO the big
Passive remote Preamplifier with Shunt Attenuator
HATTOR AUDIO Préamplificateur Passif Haute Fidélité Asymétrique Pilotable
In addition to its magnificent realization, all the conditions are present to guarantee a high level of High Fidelity reproduction. The American origin CMC 24K PTFE gold-plated connector, silver wire wiring, allows the Hattor Audio passive preamplifier to measure itself in terms of resolution against the best High End achievements on the market.
The attenuator part is equipped with high-precision 64-position Vishay SMD resistors individually tested with solid gold tracks and constant impedance inputs. The two totally separate single passive attenuators guarantee very low crosstalk thanks to their machined aluminium shields.
Ultimately refined, the two potentiometers can be dissociated to control the left or right channel separately or inversely couple them with a level difference adjustable per channel. The flexibility of operation, the number of outputs, the internal design, the quality of irreproachable components make the Hattor Audio an essential device.
Product typePassive preamplifier
Attenuator typePassive attenuator with double Shunt potentiometers with 1% switched resistors
Attenuation value10K
Input selectionx5 - Controlled by remote control
Inputs5x Single-ended RCA
Outputs4x Single-ended RCA
DisplayLED Matrix
Right and left volumes, dissociable or not-
FinitionWood, Brown Aluminium and chrome
Dimensions290 x 263 x 86mm
Weight4.2kg
Package1x Hattor Audio preamplifier
1x Switching power adapter 5V 600mA
1x IR Remote control
ColorBrown
ClassN/A
Remote ControlYes
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction...
