Passive Preamplifier Switched Resistor Volume Controller XLR / RCA
This passive preamplifier offers both balanced and unbalanced connectivity, with desymmetrization function and extremely effective volume control, all integrated into a rugged yet unobtrusive housing.
Reference : 13183
165,00 €tax incl.
137,50 € tax excl.
Passive preamplifier
Passive preamplificateur with Volume Control & desymetrizer XLR RCA
Préamplificateur passif contrôle de volume atténuateur à relais XLR RCA
Balanced AND Single-Ended
This passive preamplifier offers dual connectivity, both unbalanced with stereo RCA input and output and balanced with 3-pole XLR input and output. In addition, it also takes the function of desymmetrization since it is possible to enter XLR for output in RCA. The following connections are therefore possible:
  • Balanced XLR Input to Balanced XLR output
  • Balanced XLR input to Single-Ended RCA output
  • Single-Ended RCA input to Single-Ended RCA output
This device is not a controller, so it is not possible to use the RCA input to output in XLR.
Préamplificateur asymétrique symétrique
Efficient volume control
This preamplifier also incorporates a highly efficient 256 position switched resistor volume control. This system allows a much more efficient sound power adjustment than a conventional potentiometer. It generates less noise and offers a more transparent sound. The attenuator is based on a series of 16 Takamisawa NA12W-K relays.
Préamplificateur passif atténuateur de volume à relais
Aluminium housing
All components are integrated in a simple but robust housing, entirely made of brushed aluminium, with a silver front and the rest of the housing in black. On the front panel there is simply the volume knob offering a good grip and an LED indicating if the device is on (turning the volume knob to the right turns the device on).
At the rear are simply the RCA and XLR connectors with associated silkscreens to simply locate inputs and outputs. You will also find the power connector in IEC format as well as the presence of a fuse holder.
Device typePassive preamplifier with volume control
Volume control typeRelay attenuator
Inputs1x RCA
1x XLR
Outputs1x RCA
1x XLR
Housing material100% Brushed Aluminium
Power supply220V 50Hz via IEC (cable not included) - Fuse
Dimensions165 x 190 x 75mm
Weight1.8kg
ColorsSilver and black
InputXLR
ColorSilver
ClassN/A
This passive preamplifier offers both balanced and unbalanced connectivity, with desymmetrization function and extremely effective volume control,...
