AUDIOPHONICS PGA8-CH - Volume Controller 8 Inputs 2 x PG4311
This kit incorporating a source selector and a volume controller is a solid foundation for the development of your DIY projects.
Delivered with its remote control, it is able to learn to use one of your own remote control in order to fit in your existing elements.
Prothis module allows you to adjust an independent base volume per channel and then vary them together.
This PGA8-CH module, which can be used as a preamplifier in its own right, can also be used to control the triggering of a SOFTSTART module which is useful as part of an integration into an advanced amplifier project.
- Display 3x7 rotary encoders and sequences on a separate card.
- Rotary encoder used for volume control and input selection ON (short press) / Standby (press and hold).
- Infrared remote control.
- Memory of the settings (see function of sw1).
- Function Programmable remotely (see function of SW3).
- Display intensity control (4 levels).
- Configuration via DIP switch (SW)
-AOP on supports (easy change)
-Individual volume adjustment by channels
Configuration:
-SW1 (on): Automatically saves the configuration (Volume level, channel ...) when the power is turned off.
-SW1 (off):Reset at each start.
-SW2 (on): Display always on
-SW2 (off): The display turns off after 5 seconds without action
-SW3 (on): in remote learning mode (allows you to control the module with another remote control)
000-ON / OFF operating sequence
111-MUTE
222-Volume less
333-Volume plus
444-Channel less
555-Channel less
666-End of learning (Switch off the SW3 disconnect the module, restart the modifications are effective)
-SW4 (on) -mplified active
-SW4 (off) -no preamp (+ 0db) P>
Features:br>-PGA4311 Volume control (-95.5dB to +31.5 dB in 0.5db steps)
-MSP430 MCU
-Input 8-channel
8-Channel Output
-Display 3x7 segments red (adjustable intensity)
-Rotary encoder
- Infrared Remote Control
-Power supply (+/- 6 to 9v + 1x6v) - Recommended Toric 15VA 2X9V + 1x6V A>
P>
Dimensions:
-Main module: 150x70x33 mm
-Girl card (display): 100x20x12 mm
-Remote control: 86x40x7 mm
- Tablecloth: 14.8cm
P>
P>
P>
P>
P>
P>
