This audiophile attenuator is based on a resistance switching system guaranteeing you the best possible attenuation quality.
Delivered with 3 caches of different shades in order to adapt to all interiors and tastes.
Easy to install, it is compatible with the retention system
Input | Screw terminals |
Output | Screw terminals |
Mounting type | To screw |
Connectic | Female |
Max panel thickness (mm) | N/A |
Channel | 2 (Stereo) |
Accepts Banana Plugs | N/A |
Contacts Material (Connector) | N/A |
Contacts Plating (Connector) | N/A |
