2200Hz -24db/Oct Class-A 3 ways
This three-channels crossover uses a Linkwitz-Riley filter. A technology particularly appreciated for its remarkable performance in complex and multi-channel crossover systems.
Offering 4th order attenuation (-24dB per octave) while providing extremely flat phase response across the entire 20Hz-20kHz band, this is an ideal solution for effectively filtering your signal before injecting it into a power amplifier or active speakers.
Crossover points: 310HZ / 3.1KHZ (i.e. 20HZ-310HZ on bass output 310-3.1KHZ on medium output, 3100-20KHZ on treble output).
Specifications | |||
Type | Filter / crossover | ||
Filter | Linkwitz-Riley | ||
Crossover point | 310HZ / 3.1KHZ | ||
Attenuation slope | -24dB/Oct | ||
Inputs | 1x stereo single-ended RCA | ||
Outputs | 1x stereo single-ended RCA 20Hz-310Hz (bass) 1xstereo single-ended RCA 310Hz-3.1KHz (medium) 1x stereo single-ended RCA 3.1KHz-20KHz (treble) | ||
OPA | JRC double-precision NE5532 | ||
Dimensions | 173x79 | ||
Power Supply | double 14-19V AC | ||
Weight | 250g |
