FX-AUDIO PT2313 Volume Control Module / Tone Controller and Source Selector with Remote Control
This FX-Audio module integrates a PT2313 audio processor from Princeton Technology Corp. This allows volume, bass, treble and balance control for up to 3 different sources for your DIY amplifier modules.
4.4 / 5
Reference : 12147
14,90 €tax incl.
12,42 € tax excl.
FX-AUDIO PT2313
Volume / tone control, source selector with remote control relay switch
This extremely comprehensive module integrates a wide range of features in a compact format. It fulfills volume controller function, mute, source selector (3 stereo inputs), TONE adjustment (bass / trebble) and loudness equalizer.
This is the second version of the module that embeds a relay switch as well. This allows to establish an power sequence easily: when installed, the user can power the module and the amplifier behind it by just pressing a button on the module pannel or on the remote control.
OLED display
An OLED display is supplied with the module to allow the user to view the volume or setting of any of the parameters available in a clear and legible way.
All necessary connections to connect the screen to the main PCB are also provided. Moreover, the display medium itself serves as a connector extension for the module accessories: infra-red receiver (& provided already wired), rotary encoder (& provided already wired), control panel (supplied & already wired).
Control panel
The module comes with its own control panel. It has 4 buttons to quickly navigate between different options.
Once the setting you selected is shown, simply use the rotary encoder to move the setting to the desired value.
Relay switch
This new version of the module is now equipped with an input / output aux power line connected to a relay switch.
These connectors are not designed to supply this module, but another element of the chain which power will be subject to the ON / OFF FX-AUDIO PT2313. The architecture relay switch prevents thumps ignition.
By remote control
If the infrared receiver is installed (the latter is supplied with the module), all parameters available via the control panel can also be configured remotely using the remote control (provided as well).
Connection Diagram
Type of productController volume / tone and source selector
ChipPT2313
controlsVolume
Bass
Treble
LoudnessYes
Mute functionYes
Inputsx3
Outputsx2 *
Output # 2 provides power to a rear stereo output
Up to 3 InputsWith independent volumes
fader and balance controlsUp to 4 independent speaker
Input / Output for external system noise reduction or equalizer-
No volume control1.25dB / no
Input sensitivity775mV
Output sensitivity2V
Package Contents
PT2313 controllerx1
Screenx1
IR receiverx1
Panel buttonsx1
Rotary encoderx1
PH 3-pin cables to bare wiresx4
8 reviews
Bien mais peut mieux faire
Bonjour,
C'est le 2ème module que j'achète. Parce qu'à terme, je veux changer ou améliorer l'interface de contrôle qui ne donne toujours pas satisfaction :
- la gestion du bouton de volume,est toujours aussi mal faite, et occasionne des sautes indésirables (augmentant brusquement le volume alors que vous souhaitez le diminuer par exemple)
- pas de mémorisation du réglage de volume pour chaque canal, ce qui serait bien pratique lorsqu'il y a de fortes différences de niveau entre sources, alors que c'est indiqué exister dans le descriptif
- pas de réglage balance (bon, cela n'est pas fondamental pour moi).
- plus grave : il est arrivé que le module de contrôle ne démarre pas, m'obligeant à couper puis remettre l'alimentation.
Pas de chance : l'identification du processeur est soigneusement effacée, ce qui m'empêche de faire du "reverse engineering" pour améliorer l'interface de contrôle.
This review has been posted for FX-AUDIO PT2313 Volume Control Module / Tone Controller and Source Selector with Remote Control
Fonction mute
Bonsoir
il faut utiliser la sortie interface de contrôle, lorsque mute est affiché on retrouve 5v sur une des broches, et de la piloter des relais, comme la laisser entendre Manfred.
BON RAPPORT QUALITE PRIX
Fonctionne bien
par contre je n'arrive pas à faire marcher la fonction mute elle s'affiche sur l'écran mais ne coupe pas l'audio, si quelqu'un a la solution!
un petit synoptique ne serait pas superflu
Module intéressant
Bonjour
Je compte l'utiliser pour concevoir un préampli sélecteur de sources.
les fonctions du module on était bien décrites par Joel P .
Je regrette l'absence de la fonction balance/fader .
Je n'ai pas encore pu tester la qualité de l'audio.
Merci à AUDIOPHONICS pour ces modules.
sympas a utiliser .a par le manque de doc.
Bonjour,
Nous pensons l'illustration de la fiche décrivant tous les connecteurs satisfaisante pour utiliser ce produit.
This FX-Audio module integrates a PT2313 audio processor from Princeton Technology Corp. This allows volume, bass, treble and balance control for...
