GLA-RCA Volume Control Module 20KOhm with Encoder / Display / Remote control
This volume control module includes an encoder, a display and an IR remote control. This GLA-RCA module features a low-distortion chip (0.0015%) and a 4.2Vrms output level. Sound level is controlled over a wide range from -97dB to 0dB by potentiometer, with a volume memory function. The display shows values from 0 to 95, with one step representing 1dB. The module's supply voltage is +/-12V. DC. This module is ideal for any DIY project requiring volume control.
Reference : 18343
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 25-04-2025.
GLA-RCA Volume control module
Volume control module with Encoder / Display / Remote control
GLA-RCA volume control module components
Encoder
The encoder features a potentiometer, resistors and an NJW1194 chip. The NJW1194 is a low-noise, low-distortion 2-channel volume control chip. A 78M05 voltage regulator and STCW204S microcontroller are also integrated.
Display
On the display side, there's of course an LED screen, but also an indication LED with IR receiver. All this is supported by a 16-channel JXI5020 LED microcontroller.
Remote control
A small infrared remote control allows you to control sound level and the mute function from a distance. Very practical, it eliminates the need to move around and systematically use the potentiometer to access the volume control.
Overview of the volume control module
1Signal output 3-pin PH 2.0 connector
2Signal input 3-pin PH 2.0 connector
3Power supply +/-12V 3-pin PH 2.0 connector
4Soldering pad for additional 3-pin PH2.0 connector
5Encoder/display module connector
6Display/encoder module connector
7Display LED
8LED indicator/IR receiver
Product typeVolume control module
Input1x Signal input on 3-pin PH 2.0 connector
Output1x Signal output on 3-pin PH 2.0 connector
Volume control range-97dB to 0dB
Input impedance20KOhm
Distortion level0.0015%
Channel separation120dB
Output noise level1.4µV
Output level4.2Vrms
Remote control
Power supply+/-12V DC
DimensionsEncoder: 39 x 42mm
Display: 48 x 25mm (Spacing holes: 40x20mm / Holes diameter : 3mm)
Package1x Volume control module (encoder and display)
1x IR remote control
3x 3-pin PH 2.0 connector cable to bare wires
InputPH 2.0mm
OutputPH 2.0mm
Channel2 (Stereo)
This volume control module includes an encoder, a display and an IR remote control. This GLA-RCA module...
