GLA Volume Control Module
This GLA digital volume control module consists of an encoder and a remote control. This module is dedicated to volume control, replacing traditional mechanical potentiometers. Thanks to its integrated chips, it avoids sliding noises. Its many functions make it an ideal choice for any DIY project.
Reference : 20493
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 16-04-2025.
GLA Volume Control Module 50KOhm with Encoder and Remote Control
GLA Volume Control Module : Package content view
This GLA digital volume control module consists of an encoder and a remote control. This module is dedicated to volume control, replacing traditional mechanical potentiometers. Thanks to its integrated chips, it avoids sliding noises. Its many functions make it an ideal choice for any DIY project:
  • Volume position memory: the last volume level is retained on power-on.
  • Mute mode: using the remote control or by pressing the potentiometer.
  • Wide volume control range: -79db to +10dB
  • Pre-amplification function: this enables good output volume on low-level devices such as laptops or telephones by activating the "loudness" mode (to activate this function, short-circuit the OP1 solder joint).
  • Subwoofer signal output on solder pads: 85Hz cut-off frequency (cables for this application are not supplied).
This GLA module has an input impedance of 50KOhm with an input and output signal of 2.1Vrms (@ THD+N = 1%) for an operating voltage of between 12V and 15V DC.
Volume control module items
GLA 50KOhm Volume Control Module with Encoder
Encodeur
This PCB integrates a potentiometer, 2 voltage regulators 78M09 and 78M05, and a STC15W204S microcontroller. Inputs and outputs include a stereo signal input on a 3-pin JST connector and its output counterpart, a subwoofer output on solder pads and a 2-pin JST power supply input.
GLA 50KOhm volume control module with remote control
Remote Control
A small infrared remote control allows you to control sound level and the “MUTE” function from a distance. Very practical, it eliminates the need to move around and systematically use the potentiometer to access the volume control.
Volume controller module overview
GLA Module contrôle de volume 50KOhm : Diagram
1Stereo audio signal output 3-pin PH 2.0 connector
2Stereo audio signal input 3-pin PH 2.0 connector
3Subwoofer output on solder pads
4Power connector 12V-15V 2 pins PH 2.0
5Potentiometer with push-button
63-pin PH 2.0 connector IR receiver
7OP1 setting pads
8Voltage regulator 78M09
9Voltage regulator 78M05
10Micro controller STC15W204S
Product typeVolume control module
Input1x Signal input on 3-pin PH 2.0 connector
Outputs1x Signal output on 3-pin PH 2.0 connector
1x Subwoofer output on solder pads
Volume control range-79dB à 10dB
Input impedance50KΩ
Maximum input and output levels2.1Vrms @ THD+N = 1%
Remote controlSupplied
Supply voltage12V-15V DC on 2 pins PH 2.0 connector
Dimensions36 x 28mm
Package1x Volume control module (Encoder)
1x Remote control (battery sold separately)
2x 3-pin PH2.0 connector cable to bare wires
1x 2-pin PH2.0 connector cable to bare wires
1x 2-pin PH2.0 connector cable to IR receiver
InputPH 2.0mm
OutputSolder pad
OutputPH 2.0mm
Channel2 (Stereo)
GLA Volume Control Module 50kOhm with Encoder / Remote Control
This GLA digital volume control module consists of an encoder and a remote control. This module is dedicated to volume control, replacing...
