HYPEX PREAMPLIFIER Stereo Preamplifier DIY Kit
Design your own high-end preamplifier with this DIY Hypex DIYclassD DIY PreAmplifier kit. Thanks to the easy-to-follow instructions, you'll be able to build a high-end preamplifier cost-effectively, and in just 30 to 60 minutes. Combined with a Hypex Nilai Class D amplifier (sold separately) like the Nilai500DIY, you can create a complete package delivering incredible sound quality.
By buying this product you get 149 loyalty points
Reference : 18921
1 499,00 €tax incl.
1 249,17 € tax excl.
Hypex DIY PreAmplifier Stereo Preamplifier DIY Kit
Photo of Hypex DIY PreAmplifier mounted
Key features:
  • Fully analog
  • 2.7" monochrome OLED display
  • Remote control included
  • Modular design
  • Discrete voltage regulators and OPAs
Required tools:
  • 7mm hex nut driver
  • Wire cutter
  • 3.5mm flat type screwdriver
  • 5.5mm hex nut driver
Product typeDIY preamplifier kit
Inputs1x Balanced stereo XLR
2x Single-ended stereo RCA
Outputs2x Balanced stereo XLR
1x Balanced XLR 4 pins headphone output
1x Single-ended Jack 3.5mm headphone output
Input level14.45dBu (4Vrms)
Output level14.45dBu (4Vrms)
Headphone output level19dBu (7Vrms)
Input impedance100kΩ
Output impedance44Ω
Headphone output impedance< 0.5Ω
Noise3µV (No-wt, unitary gain)
Headphone output noise7.5µV (No-wt, unitary gain)
SNR122dB
Gain range-70dB / +13dB
THD-140dB à 1kHz, 4Vrms in, 0dB
Supply voltage90-135VAC / 180-270VAC (auto switch)
Consumption10W
Standby consumption< 0.5W
Dimensions417 x 340 x 77mm
Weight4kg
Package1x DIY preamplifier case
1x Main board
1x Front board
1x Headphone board
1x Power supply board
All necessary wiring, connectors and mounting hardware
Mounting guide
1x TX-10 / TX-20 and 1.5mm hex key
1x Remote control
InputXLR
Channel2 (Stereo)
Design your own high-end preamplifier with this DIY Hypex DIYclassD DIY PreAmplifier kit. Thanks to the easy-to-follow instructions, you'll be...
