HYPEX PREAMPLIFIER Stereo Preamplifier DIY Kit
Design your own high-end preamplifier with this DIY Hypex DIYclassD DIY PreAmplifier kit. Thanks to the easy-to-follow instructions, you'll be able to build a high-end preamplifier cost-effectively, and in just 30 to 60 minutes. Combined with a Hypex Nilai Class D amplifier (sold separately) like the Nilai500DIY, you can create a complete package delivering incredible sound quality.
By buying this product you get 149 loyalty points
Reference : 18921
1 499,00 €tax incl.
1 249,17 € tax excl.
15 - 25 Days
We are not able to give you a precise time frame for this product and this quantity. The range shown is an estimate calculated based on typical restock times for this manufacturer.
Hypex DIY PreAmplifier Stereo Preamplifier DIY Kit
Photo of Hypex DIY PreAmplifier mounted
Key features:
  • Fully analog
  • 2.7" monochrome OLED display
  • Remote control included
  • Modular design
  • Discrete voltage regulators and OPAs
Required tools:
  • 7mm hex nut driver
  • Wire cutter
  • 3.5mm flat type screwdriver
  • 5.5mm hex nut driver
Product typeDIY preamplifier kit
Inputs1x Balanced stereo XLR
2x Single-ended stereo RCA
Outputs2x Balanced stereo XLR
1x Balanced XLR 4 pins headphone output
1x Single-ended Jack 3.5mm headphone output
Input level14.45dBu (4Vrms)
Output level14.45dBu (4Vrms)
Headphone output level19dBu (7Vrms)
Input impedance100kΩ
Output impedance44Ω
Headphone output impedance< 0.5Ω
Noise3µV (No-wt, unitary gain)
Headphone output noise7.5µV (No-wt, unitary gain)
SNR122dB
Gain range-70dB / +13dB
THD-140dB à 1kHz, 4Vrms in, 0dB
Supply voltage90-135VAC / 180-270VAC (auto switch)
Consumption10W
Standby consumption< 0.5W
Dimensions417 x 340 x 77mm
Weight4kg
Package1x DIY preamplifier case
1x Main board
1x Front board
1x Headphone board
1x Power supply board
All necessary wiring, connectors and mounting hardware
Mounting guide
1x TX-10 / TX-20 and 1.5mm hex key
1x Remote control
Input
  • RCA
  • XLR
Output
  • XLR
Channel
  • 2 (Stereo)
Design your own high-end preamplifier with this DIY Hypex DIYclassD DIY PreAmplifier kit. Thanks to the easy-to-follow instructions, you'll be...
