Input Selector Board 4 Channel with Display and Remote Control CS3310
This module consists of a source selector with 4 stereo RCA inputs and an analog output on a 2.54mm XH connector, as well as a VFD display. The management of the audio streams is entrusted to a Cirrus Logic CS3310 16bit chip.
Reference : 15009
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 25-04-2025.
Module sélecteur de source 4 canaux avec afficheur et télécommande
This module consists of a source selector with 4 stereo RCA inputs and an analog output on a 2.54mm XH connector, as well as a VFD display. The management of the audio streams is entrusted to a Cirrus Logic CS3310 16bit chip, ensuring low distortion. The display can show 9 digits and a potentiometer on its right side allows to switch on/off the module, to select an active source or to adjust the volume level. The supplied remote control also allows remote access to these functions.
Module sélecteur de source 4 canaux avec afficheur et télécommande Module sélecteur de source 4 canaux avec afficheur et télécommande
The connector near the relays is in parallel with RCA input 1 (IN1). If you have an internal source such as a Bluetooth module, you can assign it to IN1 (the RCA input is then no longer usable).
The P5 connector allows you to modify the maximum output level.
P5 ON : 31.5dB maximum output level.
P5 OFF : 0dB maximum output level.
The P3 connector corresponds to the memory mode at start-up.
P3 ON : Start-up state on IN1 and level at -46dB.
P3 OFF : Start up at the last state with switch off.
The J1 connector allows a manual control by button (a contact to the ground of each line is enough).
MUTE : Mute mode.
1-2-3-4 : Direct selection of inputs 1, 2, 3 and 4.
V- : Volume -
V+ : Volume +.
Product typeInput selector module
Inputs4x Stereo RCA
Output1x XH 2.54mm analog output
DisplayVFD
Remote control(2x AAA 1.5V batteries required, sold separately)
Rated current500mA
Control modeSPI
Channel crosstalk-130dBFS
Dynamic range-120dB
THD+N0.0004% @ 1kHz
Power supply12V AC (sold separately)
Input selector board dimensions177 x 59mm
Input selector board mounting holes spacing144 x 31.5mm
Display board dimensions168 x 37.5mm
Display board mounting holes spacing161 x 30.5mm
Weight200g
Package1x Input selector board
1x Display
1x Remote control
1x Audio output cable
1x Interface cable for selector/display modules
1x Button (random color)
OutputXH 2.54mm
Channel2 (Stereo)
This module consists of a source selector with 4 stereo RCA inputs and an analog output on a 2.54mm XH connector, as well as a VFD display. The...
