le plus gros problème que j'ai rencontré est la fiabilité des relais de commutation (2 relais ne fonctionnaient pas correctement, j'ai du les remplacer).
By buying this product you get 27 loyalty points
LITE V03 RA - "Symmetrical" Switch Volume Controller
High-End Relay Stereo Volume Controller 25ppm
This volume controller uses relays to switch resistors, in the manner of a rotary selector.
This allows a completely passive volume attenuation without components that can cause distortion or staining.
This version of the V03 is equipped with Resistances RA USA 25ppm
Average votes 3.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Lucien P.
