LITE V3310 2ch - 2-way volume control module CS3310
4.7 / 5
Reference : 3609
54,90 €tax incl.
45,75 € tax excl.
2-channel RCA balanced digital volume controller
Complete ready-to-run card set.
For 2 unbalanced channels the kit includes:
  • A controller card
  • 1 volume control card
  • A remote control
Each card has an input selector and volume control, which are synchronized by the control board.
Since each card has 4 entries it is possible to connect 4 RCA sourcesto an output 2 attenuated RCA channels.
Ideal for managing the volume of connected devices in RCA
Features:/ Span>
  • Crystal Semiconductor CS3310 Digital Volume Controller
  • Signal to Noise Ratio 116dB
  • 0.001% THD + N
  • Channel separation 110dB
  • Stabilized power supply on each board (direct supply by toric)
  • Volume -80dB to 0dB + Mute
  • Control by remote control or front button
  • 4 relay selectable inputs (on each board)
  • Display of the selected input and volume
  • Dimensions of the cards:
    Volume: 250x60x26mm
    Control: 230x52x10mm
It remains to add a transformer toric 12VAC and a transformer 9VAC of 15VA as well as the wiring.
Photo of kit:
Cable schematics
https://www.audiophonics.fr/images2/5440/5440_schema_3310.jpg
Example of equipment required for assembly:
This list is not exhaustive, you may need thermo sheath, welding, screws ...
On our model the facade was simply fixed to the double face, which avoids making fixing holes in the facade but does not facilitate the use of the buttons.
InputPCB Connector
InputSolder pad
OutputSolder pad
OutputPCB Connector
Channel2 (Stereo)
3 reviews
carte relais
Bonjour,
commande reçue hier, hormis 2 transistors tordus sur la carte relais, le reste étant conforme
This review has been posted for LITE V3310 2ch - 2-way volume control module CS3310
Good product
I am using this remote control combo already for quiet some time, and to my complete satisfaction. Although it doesn't feature the newest of chips it's performance is still very well up to date, in the best sense of acoustical absenteeism in the signal path. I hope it'll stay available for some further time. Recommended.
Très bon module, je l'utilise depuis quelques mois déjà et je n'ai aucun soucis avec, pleinement satisfait. Par contre je voudrais savoir si il est possible de faire en sorte a ce que la configuration du canal et du volume ne se reset pas a chaque redémarrage. Si oui comment, ce serait vraiment pratique. Merci
