LQSC Preamplifier Board with Volume and Tone Control 2x NE5532
This quality preamplifier module is based on the use of two NE5532 AOPs, allowing a clear and musical reproduction. These are mounted on DIP8 brackets and are therefore easily replaceable to adapt the sound signature of the module.
Reference : 16220
19,90 €tax incl.
16,58 € tax excl.
Preamplifier board
Module préamplificateur atténuateur de volume avec contrôle de tonalité 2x NE5532
It also incorporates a volume controller and two tone controls, offering the ability to adjust the bass and treble gain over a range of ±8dB.
For its connectivity, the module provides in input and output a 3.5mm jack and XH2.54mm connectors.
Product typePreamplifier board with volume and tone control
OPANE5532
Inputs1x Jack 3.5mm
1x XH2.54mm 3 pins
1x XH2.54mm 6 pins
Outputs1x Jack 3.5mm
1x XH2.54mm 3 pins
1x XH2.54mm 6 pins
Output power2x770mW @ 32Ω, 24V
SNR98dB
THD+N< 0.01%
Tone controlBass: 100Hz, ±8dB
Treble: 10kHz, ±8dB
Supply voltage9-24VDC via Jack DC 5.5/2.1mm
Dimensions72 x 53 x 15mm
Mounting holes spacing47.58 x 36mm
Accessories1x LOSC Preamplifier board
Wiring
PCB Connectors
InputJack 3.5mm
InputXH 2.54mm
OutputJack 3.5mm
OutputXH 2.54mm
Channel2 (Stereo)
This quality preamplifier module is based on the use of two NE5532 AOPs, allowing a clear and musical reproduction. These are mounted on DIP8...
