Passive XLR balanced passive Volume control module with 256-level relay
Passive XLR balanced passive volume controller with 256-level relay controller
This high-precision 256-stage volume controller is ideal for the design of passive or active preamplifiers in XLR symmetric or classical RCA asymmetric design.
Strengths:
  • Perfect channel balance
  • Analog bridge meter supplied
  • Digital Analogue Controller ADC0804
  • Same linear quality as a switched resistance potentiometer
  • Integrated circuit power supply
Reference : 12476
79,00 €tax incl.
65,83 € tax excl.
 Attenuator stereo relay Module
This relay balanced stereo volume attenuator module allows for the design of high quality and precision preamplifiers. The principle is simple. An analog potentiometer sends an analog voltage to control an 8-bit ADC controller that opens and closes relays on precision resistors.
The principle is the same as the switched resistance potentiometers in terms of audio output. Listening to this type of technology allows a great amount of details, a dynamqiue acrrue contrary to a carbon potentiometer showing a high noise level and a greater distortion at low volume.
This attenuator has balanced inputs and outputs that can be doubled by RCA inputs and outputs to be soldered on the PCB.
It can be used either as a passive attenuator or coupled with active preamplifier buffer modules.
TECHNICAL CHARACTERISTICS
  • Separate left and right design
  • 3 inputs, one output
  • Gold Plated Circuit
  • Capacitors: SIC and WIMA
  • Power Transistors: ZTX450 / ZTX550
  • Resistors: DALE and BI
  • Source selector potentiometer
  • Transformer input voltage: AC 14V x 2 to AC 18V x 2
  • Dimensions: 155 x 136 x 46 mm
  • Mounting hole spacing: 140 x 120 mm
InputXLR
Channel2 (Stereo)
This high-precision 256-stage volume controller is ideal for the design of passive or active preamplifiers in XLR symmetric or classical RCA...
