Preamplifier Module 6 Channels RCA with OLED Screen
This preamplifier module has six channels and can be used in HiFi mode with two channels or in 5.1 home cinema mode. It integrates a volume control based on an M62446 chip.
Reference : 16920
32,90 €tax incl.
27,42 € tax excl.
Preamplifier module
6-channel RCA with OLED display
Module préamplificateur 6 Canaux RCA avec Écran OLED
This preamplifier module has six channels and can be used in HiFi mode with two channels or in 5.1 home cinema mode. It integrates a volume control based on an M62446 chip. This allows to adjust the level of all 6 channels synchronously or to adjust independently the level of the front, center, bass and surround channels. The adjustment can be made using the built-in potentiometer. A display shows these settings for easy operation. An equalization system also allows the adjustment of the bass and treble levels. The input is made in stereo RCA and the output with a connector XH 2.54mm 7 pins.
Screen
1Input mode
2Treble level
3Bass levle
4Selection of the channel to be controlled
5Playback status
6Volume levle
RCA Connectors
1Left channel AUX input
2Right channel AUX input
3Left channel input (5.1 mode)
4right channel input (5.1 mode)
5Center channel input (5.1 mode)
6Subwoofer input (5.1 mode)
7Left channel surround input (5.1 mode)
8Right channel surround input (5.1 mode)
9Left channel output
10Right channel output
11Center channel output
12Subwoofer output
13Left channel surround output
14Right channel surround output
XH 2.54mm output
1GND
2LO : Left channel output
3RO : Right channel output
4C : Center channel output
5SB : Suwboofer output
6SL : Left channel surround output
7SR : Right channel surround output
Product typePreamplifier module
Number of channels6
InputsRCA
OutputsRCA
XH 2.54mm
Volume control chipM62446
OPA3* NE5532S
ScreenOLED
Supply voltage5-12VDC via USB-C (power supply sold separately)
Preamplifier module PCB dimensions125*100mm
Remote controlIncluded
OutputJack 6.35mm
Channel2 (Stereo)
Channel5.1
Channel6
This preamplifier module has six channels and can be used in HiFi mode with two channels or in 5.1 home cinema mode. It integrates a volume control...
