Preamplifier module with volume / bass control NE5532 DIP8
Reference : 11652
19,90 €tax incl.
16,58 € tax excl.
This preamplifier module with volume and bass control (frequency range 50Hz-150Hz) has two DIP 8 supports to change the AOP (operational amplifier) ​​as it sees fit. It requires only a small transformer from 15 VA 230 V AC to 12 V on a secondary to operate.
It will allow to use any stereo signal in input and to leave it in mono to attack a monophonic amplifier and therefore a single speaker. It is recommended for DIY design of subwoofer for example.
You can change the OP NE 5532 amps byOP2134to get a warmer, analog sound.
Characteristics :
  • AOP Texas Instruments NE5532 on DIP 8 supports (interchangeable)
  • 2 Potentiometers 50K Ohm (one for volume, second for bass correction)
  • Requires 15V VAC for power supply
  • Dimensions: 103x90x28mm
  • Weight: 66g
  • Wiring not supplied
[Img-21675-left-thickbox_default]
[Img-21677-left-thickbox_default]
  • A: Straight line input (RN)
  • B: Left line input (LN)
  • E: Ground GND
  • C: Variable line output -
  • D: Line output goesriable +
  • F: Ground GND
  • G: Input: VAC 15V
  • H: Input: VAC 15V
  • I: mass GND
schéma préampl ampli NE5532 BTL
schéma préampl ampli NE5532 non BTL
Channel2 (Stereo)
