Preamplifier Volume Attenuator Module with Tone Control 2x LME49720NA
This module combines the functions of preamplifier and volume control with tone control. It therefore allows you to act independently on bass, midrange and treble via different potentiometers. It incorporates two DIP8-mounted LME49720 OPAs, easily interchangeable according to your preferences in terms of sound rendering or your needs in relation to your Hi-Fi installation.
Reference : 18360
26,90 €tax incl.
22,42 € tax excl.
With Tone Control 2x LME49720NA
Volume Attenuator Preamplifier Module with Tone Control 2x LME49720NA
This module combines the functions of preamplifier and volume control with tone control. It therefore allows you to act independently on bass, midrange and treble via different potentiometers. It incorporates two DIP8-mounted LME49720 OPAs, easily interchangeable according to your preferences in terms of sound rendering or your needs in relation to your Hi-Fi installation. It also incorporates a 7812T voltage regulator, an HK19F relay and 2 TL431AC low-noise Class A linear voltage regulators coupled to BC139 and BD140 transistors. Note that a bypass mode is available by turning the treble control potentiometer to the far left until it passes a switch position, which disables the tone control function.
Signal input and output are via two screw terminals. The module is powered from a voltage range of 12-0-12V to 18-0-18V AC via a screw terminal input.
If you wish to use the PCB or potentiometers outside an enclosure, they must be grounded to avoid any interference.
Overview of the volume control preamplifier module
1AC power supply input 12-0-12V to 18-0-18V
2Bass adjustment potentiometer
3Medium adjustment potentiometer
4Treble control potentiometer / tone control off
5Volume control potentiometer
6 Grounding solder pad
7Stereo signal output
8Stereo signal input
Product typePreamplifier module
Volume control
Tone control
Tone controlTreble
Midrange
Bass
Volume control
OPA2x LME49720
Voltage regulatorsTL431AC
Transistors1x BC139
1x BD140
Power supply12-0-12V AC
18-0-18V AC
Dimensions145 x 66mm
Spacing holes135 x 57mm
Weight120g
Package1x Preamplifier volume attenuator module with tone control
InputScrew terminals
OutputScrew terminals
Channel2 (Stereo)
This module combines the functions of preamplifier and volume control with tone control. It therefore allows you to act independently on bass,...
