Volume control module / Display / Remote control
4.8 / 5
Reference : 13447
17,90 €tax incl.
14,92 € tax excl.
Shipping date: 25-04-2025.
Volume control with potentiometer, display and remote control
This comprehensive module is ideal to easily add a modern and intuitive control volume to your DIY contructions.
It functions as a voltage divider with many internal resistors. Its volume accuracy reaches 1dB.
The module comes with a range of accessories which have been selected and configured to work with. A two-digit display indicating the volume level, with appropriate wiring for connecting said screen, a rotary potentiometer already mounted on the PCB and even an infra-red remote control.
Easy installation
The potentiometer dedicated to volume control comes alreay installed on the PCB. This is a conventional rotary potentiometer with nut mounting directly on a device's facade.
All inputs and outputs are already equipped with appropriate connectors. There are input / output terminals for the left / right channels, one is dedicated to power supply and another terminal allow to use another infrared receiver if the one that is provided does not suit your needs.
A six-way XH2.54mm connector is in charge of interconnecting with the digital display that comes with the module. The cable for this purpose is supplied as well.
Module control volume diy High fidelity
volume control module with digital display hi fi
Digital display
A LED digital display comes with the module. It is mounted on a separate PCB to facilitate the integration of all types and in various housings.
Depending on the position of the potentiometer and the state of the voltage divider, the volume will be displayed on a scale starting from 0 tol 79.
The state zero means the device is muted.
Remote control
A remote is provided with the module.
It allows to operate remotely the following aspects: volume up,volume down and mute the unit.
The remote control communicates with an infrared receiver which is mounted on the front display PCB. It allows a very user-friendly installation since the receiver I / R is set default near the display.
However, one can use the remote control without using the display. Indeed, another infrared input is to be found on the main PCB. Similarly, the terminals are already provided for this purpose.
Module hi volume controller with remote control
Installation Diagram
How to connect volume control unit diy
Card Dimensions Main unit and potentiometer
Mounting spacing (display)
Display dimensions
Typevolume control module
ModeVoltage divider
InterfaceRotary potentiometer 360 °
IR remote control (provided) - NEC protocol
Volume controllerPT2257
InputsTerminal 2 channels (L / R / GND)
Potentiometer axisNotched
Potentiometer drilling diameter6.7mm
Display (supplied)LED display 2 digits
0-79
Power supply (not included)+ 12 ~ 16VDC
Dimensions39x42mm
Parts supplied
Volume control modulex1
Digital displayx1
Interconnect Cable XH 2.54mmx1
Remote I / Rx1
InputScrew terminals
OutputScrew terminals
Channel2 (Stereo)
5 reviews
Bass missing
Works nice but sounds like it has a 12 dB highpass filter at 200 Hz. Not suitable for any system that is supposed to play bass.
This review has been posted for Volume control module / Display / Remote control
IMPECCABLE !
Matériel facile à monter. Entrée, Sortie, Alimentation 12 V. Attention il faut une alimentation bien filtrée !
compact and easy to wire up, works very well. I am very happy!. terry.
Extrêmement utile...
Ne pas utiliser une alimentation à découpage avec ce module.
Même avec une alimentation linéaire, un accrochage se produisait lorsque je déplaçais le câble d'alimentation 12V.
Cela a été résolu en soudant une capa de 470nF entre le - et le + 12V.
easy to install
