FX-AUDIO TUBE-P1 Valves Amplifier with Phono MM Input 6J1 + 6P1 Stereo Black
FX-AUDIO TUBE-P1 Valves Amplifier and Phono MM Preamplifier 6J1 + 6P1 Stereo
The FX-Audio Tube-P1 is a tube amplifier with phono preamplifier input, based on 2 tubes 6J1 and two tubes 6P1. It is therefore ideal for those who want both a tube amplifier and a vinyl turntable.
4.8 / 5
Reference : 12725
109,00 €tax incl.
90,83 € tax excl.
FX-Audio Tube-P1
Valves amplifier with Phono MM Input 6J1 + 6P1 Stereo
FX-Audio Tube-P1 amplificateur à tubes et Préamplificateur Phono
A valves amplifier with phono input combo
FX-Audio proposes with its Tube-P1 a simple but versatile device having the particularity to be a tube amplifier allowing to deliver 2 x 2.5W but also having a phono input. It will therefore be particularly suitable for anyone who wishes to have a tube amplifier while taking advantage of its vinyl turntable.
Thus, Tube-P1 offers on the one hand a stereo RCA input that will allow you to connect most of your audio sources (CD player, tuner, network player...) and on the other hand a phono RCA input, the latter only accepting MM cell boards. Of course, we notice the presence of a connector to connect the ground of your turntable.
On the output side, there is a front headphone output in 6.35mm Jack format and at the rear an output on speaker terminals, accepting banana plugs. Small particularity, the Tube-P1 proposes a double terminal block in 4Ω and 8Ω, according to your speakers.
Recommended heating time: 20 seconds
Caution: The tubes rise to a high temperature. Do not touch the tubes when in operation and keep out of reach of children. Danger of burns.
Power2.5W + 2.5W
Valves2x 6J1 (Inclued)
2x 6P1 (Inclued)
InputsRCA
Phono (MM)
OutputsSpeakers terminals (4Ω / 8Ω)
Headphone output Jack 6.35mm (16-300Ω)
Power supply12V 4A on Jack DC 5.5/2.1mm (included)
InputPhono
OutputSpeaker terminal
OutputJack 6.35mm
ClassTube amp
4 reviews
Adorable amplifier
Φαίνεται κατασκευασμένος σαν τανκς πολύ καλή αίσθηση των πλήκτρων μεταλλικό ποτενσιόμετρο φωνής ήχος πρώτη εντύπωση μεγάλο soundstages αναλυτικά και αέρινα tweeters αναιμικο bass δεν κάνει για σύγχρονη ηλεκτρονική μουσική με πολλά μπάσα τέλειο για ακουστική μουσική και πιάνο άνετα φτάνει σε στάθμες άνω των 80 db με ηχεία μέτριας ευαισθησίας σαν τα δικά μου gale monitor mk2 .δεν κάνει για πάρτυ πολύ ήσυχος τέλειο για χαμηλές νυχτερινές ακροάσεις.για αυτούς που ξέρουν
This review has been posted for FX-AUDIO TUBE-P1 Valves Amplifier with Phono MM Input 6J1 + 6P1 Stereo Black
Bonnes bases!
Bonnes bases!
Après plusieurs jours de rodages, de tests et de combinaisons, on s'était dit avec mon pater que ce serait cool de lasser un petit avis... plus ou moins long
Alors, pourquoi le P1? Sûrement par mon saut dans le monde FX-Audio, avec le Tube 02 (ampli casque) et le Tube 03 (pré-amp). Saut qui n’a pas été sans conséquences. Des appareils assez Impressionnants, surtout le petit Tube 03. Les produits FX-Audio semble vouloir dépoussiérer le rapport qualité/prix. Surtout après un changement des tubes-stock. Oui les tubes fournis ne sont pas mauvais-mauvais, mais un changement par des équivalents (comme le GE 5654 présent sur le site) ou des NOS Russes/Américains/British/Allemands ne feront qu’apporter de vrais plus. Il est d'ailleurs difficile de faire marche arrière après ces modifications, paroles d'audiophiles.
Le P1 semble suivre la même logique que le Tube 02 et 03, prix attractif et bonne base avec un choix de tube équivalent assez large sur le marché. C’est un appareil intéressant, avec de bons composants électroniques (des photos qui circulent sur le net où l’on remarque des éléments de choix) comme des condos Wima et Nichicon. On peut se demander comment ils font pour rentrer tout ça dans le prix…
Bref, au même prix c’est sûr qu’en Classe D ça se bouscule déjà pas mal côté choix. Sauf qu' en ampli à loupiote, ‘faut enquêter. D’ailleurs merci Audiophonics pour votre prix, apparement le plus bas du net!
J’ai mis quatre étoiles pour deux raisons (à destination du fabriquant):
- l’alim a lâché au premier démarrage. Comment reconnaître la panne: son brouillon avec craquements et manque de puissance. On a pensé que les tubes étaient en fin de vie. Un branchement sur alimentation de labo (indiquant une crête de consommation de 2,75A) a permis de repérer la panne. Merci à la rapidité du SAV Audiophonics pour l’alim de rechange
- la prise de l’alim n’est pas assez serré et pas très profond…
Côté écoute, il a fallu du temps et plusieurs combinaisons sur des sources Vintage (Philips CD880 ou Marantz CD80) et câblés OFC plaqué-argent chez Audiophonics. Idem côté câblage Haut-Parleurs (branché en bi-cablâge); des Supravox 215 RTF en baffle-plan et tweeter Dayton AMT (visibles sur le site). Le pré-amp Tube 03 s’insère parfois entre la source et l’ampli:
- les tubes-stock 6P1 sonnent mieux après 20h de rôdage. Attente d’adapteur pour passer en 6AQ5 / EL90 et en EL85 que mon père a en stock
- Les 6J1 ont un médium assez prononcé, et ont été remplacés par des 6AK5 et/ou EF95
Attention à la chaleur très élevée des tubes, même quelques dizaines de secondes après leurs fonctionnements. Manipulations réservés aux connaisseurs!
Conclusion, le tube P1 intègre de bonnes bases pour découvrir à prix doux l’univers de ce genre d’amplificateur. Pour 2,5W par canal, c’est amplement suffisant. On retrouve l’aération et le volume sonore typique aux amplis à tubes.
Peut-etre un jour un P1 Mark II ? :-)
Sorprendente Ampli.
Sorprendente amplificador por su pequeño tamaño pero sonido espectacular. Buena potencia. Sonido calido y cristalino. Ideal para empezar con la tecnología de amplificadores a valvulas.
le son tube à prix cassé!
Bluffant pour le prix. Un tout petit ampli qui cache bien son jeu: une puissance minimaliste sur le papier mais aucun pb avec des enceintes à haut rendement (bouton de volume au quart de la puissance) et une pêche étonnante... une écoute plaisir, chaleureuse et transparente, de la présence...sans compter les capacités de progression en changeant de tubes. Idéal pour s'initier aux tubes à moindre frais!
The FX-Audio Tube-P1 is a tube amplifier with phono preamplifier input, based on 2 tubes 6J1 and two tubes 6P1. It is therefore ideal for those who...
