HATTOR AUDIO THE BIG Balanced Passive Preamplifier Vishay SMD Black / Silver
By buying this product you get 104 loyalty points
Reference : 10709
1 049,00 €tax incl.
874,17 € tax excl.
Shipping date: 12-03-2025.
This remotely controllable passive preamplifier with dual precision 1% SMD resistor attenuators offers the very latest in sound reproduction refinement.
Both a passive preamplifier and selector of 2 RCA sources, 3 XLR and 4 outputs (2 RCA, 2 XLR), this device with its aluminum and black carbon finish is sure to impress.
It's equipped with top-quality components assembled by hand with the utmost care.
In addition to its magnificent craftsmanship, all conditions are met to guarantee a high level of High Fidelity reproduction.
Original American CMC 24K PTFE gold-plated connectors and silver wire cabling enable the Hattor Audio passive preamplifier to compete in terms of resolution with the best high-end products on the market.
The attenuator section is equipped with high-precision, individually tested 64-position Vishay SMD resistors with solid gold tracks and constant-impedance inputs.
The two totally separate passive mono attenuators guarantee very low crosstalk thanks to their machined aluminum shields.
As the ultimate refinement, the two potentiometers can be dissociated to control the left or right channel separately, or conversely to couple them with an adjustable level difference per channel.
The flexibility of operation, the number of outputs, the internal design and the impeccable quality of the components make the Hattor Audio a must-have device.
Features:
  • Passive attenuator with double potentiometers Shunt with 1% switched resistors
  • Remote-controlled selection of 5 sources
  • 2 unbalanced RCA inputs
  • 3 balanced XLR inputs
  • 2 balanced XLR outputs
  • 2 balanced RCA outputs
  • LED matrix display
  • Left and right volumes can be separated or not
  • Carbon black and chrome finish
  • Dimensions: 290 x 263 x 86 mm
  • Weight: 4.2kg
  • Supplied with mains adapter (5V 600mA) and IR remote control (Metal and Carbon)
Volumes droite et gauche dissociables.
InputXLR
ClassN/A
Remote ControlYes
Excellent "pré-atténuateur"
Lorsque le niveau ligne est plus que suffisant, il devient inutile, voire dommageable de pré-amplifier le signal avant l'ampli (enceintes HR, ampli puissant...). Le Hattor "préamplificateur passif" (un préatténuateur, en fait) est alors une solution de choix pour moduler le signal à la perfection, dans le sens requis. Toutes les qualités audio sont au rendez-vous.
This review has been posted for HATTOR AUDIO THE BIG Balanced Passive Preamplifier Vishay SMD Black / Silver
