AUDIO-GD HE-1 Class-A Balanced Preamplifier ACSS XLR RCA
Again Audio-GD strikes hard with its HE-1 of the series HE (evolution MASTER series) proposing a symmetrical Class A preamplifier of an exceptional quality.
KEY POINTS:
  • preamplifier
  • Class A
  • symmetrical
  • ACSS
By buying this product you get 234 loyalty points
Reference : 9476
2 349,00 €tax incl.
1 957,50 € tax excl.
This product has been replaced by the new version, l'AUDIO-GD HE-1 MK2 Preamplifier.
Audio-GD HE-1
Class A / Symmetric Preamplifier
Audio-GD HE-1
One of the best preamplifiers in the world ...
Audio-GD introduces us once again to the quintessence of audio technology with the products of the HE series (Here the HE-1), evolution of the series MASTER. They have enjoyed the longest duration of design and testing in the history of the famous brand.
Samee if Audio-GD had already studied the products since 2006, the best technicians of the firm offer them here in the most accomplished form with extraordinary performances.
Exquisite interior and connectivity
It has no less than 5 analog inputs for all needs: 2x RCA / 2x XLR / 1x ACSS, along with 3 analog outputs: XLR / RCA / ACSS. Great musicality thanks to an exceptional dynamic and a rich and extremely detailed.
Chathat Audio-GD is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
Back Audio-GD HE-1
ACSS
ACSS
Audio-GD has its own technology signature called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and know-how of the firm, this technology offers a less colored, more detailed sound, and an unparalleled neutrality.
Chaque engineer technician of the brand is, in addition to being experienced, a passionate of HiFi and Audio like you and us. Namely, when the ACSS output is used,the XLR and RCA output switches to MUTE.
Remote Control Metal
This HE-1 comes with its metal remote control, brushed aluminum finish. You will find 2 buttons to switch between your different sources, as well as 3 buttons to adjust the volume: Plus / Minus / Mute. The whole class and softening of Audio-GD are visible from this remote, as it is functional and purified.
Audio-GD HE-1 Remote Control
SNR> 130dB
THD<0.0005%
Frequency Response (XLR)20Hz - 20kHz (0dB) / 100Hz - 100kHz (-1.5dB) / 1Hz - 300kHz (-3dB)
Volume control by potentiometer100 exponential steps
Gain+ 8dB (XLR) / + 16dB (RCA)
Max Output Level19V (XLR) / 9.5V (RCA) / 4.8mA (ACSS)
Input impedance94KΩ (XLR) / <5Ω (ACSS)
Output Impedance10Ω (XLR) /> 10MΩ (ACSS)
crosstalk<-130dB
Power260W (3 transformers)
Various
Consumption70W (Class A)
Weight19kg
Housing material100% Aluminum
Dimensions430 x 450 x 125mm
Digital displayYes
AccessoriesPower cable / Remote control
InputACSS
InputXLR
OutputACSS
ClassClass A / AB
Remote ControlYes
Après avoir longtemps admiré l’architecture, les caractéristiques de ce préampli et de l’ampli Master 3 qui va avec, je me suis enfin décidé à franchir le pas.
Car il faut du courage pour résister aux sirènes de la pub, des rédacteurs payés à la ligne ou au compliment et abandonner les marques et leur marketing aliénant pour acheter chinois.
Je ne le regrette pas bien au contraire !
Ces deux appareils pèsent à eux deux près de 60 kg (qui dit mieux) tels que les canons de la vrai Hifi le préconisent depuis des décennies et on en a plus que pour son argent.
En sortie j’ai 2 panneaux Magnepan 20.7, immenses et gourments en courant, qui maintenant sonnent magnifiquement et remplissent parfaitement une grande pièce de 75m².
- l’ampli Master 3 est très classique, chauffe peu, 450w très purs, pousse très fort et en silence entre les plages. Car j’ai connu un gros ampli intégré d’une marque prestigieuse qui vibrait si fort entre les plages…..
- le préampli est une merveille : des aigües fins et déliés jamais agressifs, des détails que je n’avais pas encore entendus comme la respiration de musiciens ou des pages de partition que l’on tourne.
La musique est ample c’est ce qui surprend le plus, les attaques sont très franches et les solos de batterie incroyables. La scène sonore est élargie et beaucoup plus profonde.
Les voix sont extraordinairement présentes, incarnées.
Les basses sont très profondes et parfaitement naturelles et les contrebasses ont enfin une largeur normale ! On entend, on voit, la corde et son grain, l’archet. Quel plaisir !
Mais il faut des enregistrements à la hauteur, la seule limite est là.
L’association de ces deux appareils est une réussite : la main de fer et le gant de velours.
Bref je ne regrette pas mon choix, je regrette de ne pas l’avoir fait plus tôt !
Je remercie Audiophonics d’aller dénicher au bout du monde des produits capables de sonner aussi bien mieux même que ceux que l’on nous présente partout mais cinq ou dix fois moins chers.
This review has been posted for AUDIO-GD HE-1 Class-A Balanced Preamplifier ACSS XLR RCA
Again Audio-GD strikes hard with its HE-1 of the series HE (evolution MASTER series) proposing a symmetrical Class A preamplifier of an exceptional...
