AUDIO-GD HE-9 Balanced Preamplifier / Headphone Amplifier ACSS RCA XLR
The HE-9 from Audio-GD, belonging to the HE range (evolution of the MASTER series) has benefited from an extended design time to lead to an unprecedented balanced headphone preamplifier / amplifier!
Reference : 9478
2 399,00 €tax incl.
1 999,17 € tax excl.
Including 1,00 € for green tax
Audio-GD HE-9
Preamplifier / Headphone Amplifier / Symmetry
Audio-GD HE-9
An audiophile-proof versatility ...
Audio-GD introduces us once again to the quintessence of audio technology with the products of the HE series (here the HE-9), evolution of the series MASTER. They have enjoyed the longest duration of design and testing in the history of the famous brand. Even if Audio-GD had already studied the products since 2006, the best technicians of the brand offer them here in the most accomplished form with extraordinary performances.
For yous Make a precise idea of ​​this little jewelery, find a complete test (En Français!) of this HE-9 on the site Nomade: Test Audio-GD HE-9.
Exquisite interior and connectivity
This HE-9 has no less than 5 analog inputs to support all needs: 2x RCA / 2x XLR / 1x ACSS, along with 3 analog outputs: XLR / RCA / ACSS. Not forgetting of course the headphone outputs on the front panel: XLR 3 PIN / XLR 4 PIN / Jack 6.35mm, all 3 Stereo.
Each Audio-GD product is scrupulously tested in all seams with one of the most powerful systems in the world: the Audio Analyzers 2700 Series from Audio Precision.
Arrière Audio-GD HE-9
HIGH FIDELITY in the way Audio-GD
Class A / Symmetric / ACSS / XLR / RCA
This headphone amplifier / amplifier HE-9 is designed around a discrete circuit purely symmetrical Class A ACSS, without any PDO with separate power supply. This prevents electromagnetic interference on the processed signals.
heis equipped with no less than 3 R-Core transformers for a total power of 260W and a consumption of only 95W. It also has 100,000uF of very high-end Nover capacitors and 8 transistors of 150W each for the output stage.
Audio-GD HE-9
ACSS
ACSS
Audio-GD inhas its own technological signature called ACSS for "Audio-GD Current System Signal". Thanks to the expertise and know-how of the firm, this technology offers a less colored, more detailed sound, and an unparalleled neutrality.
Every professional engineer of the brand is, in addition to being experienced, a passionate of HiFi and Audio like you and us. That is, when the ACSS output is used, the XLR and RCA outputs go to MUTE.
Remote Control Metal
This HE-9 comes with its metal remote control, brushed aluminum finish. You will find 2 buttons to switch between your different sources, as well as 3 buttons to adjust the volume: Plus / Minus / Mute. The whole class and softening of Audio-GD are visible from this remote, as it is functional and purified.
rac "> Frequency Response (XLR)
SNR> 130dB
THD<0.0008%
20Hz - 20kHz (0dB) / 10Hz - 100kHz (-0.7dB) / 1Hz - 320kHz (-3dB)
Gain (XLR)+ 14dB (Low gain) / + 20dB (High gain)
Max Output Level19V (XLR) / 9.5V (RCA) / 4.8mA (ACSS)
Input impedance94KΩ (XLR) / <5Ω (ACSS)
Output Impedance10Ω
Symmetrical headphone output power9000mW (40Ω) / 3800mW (100Ω) / 1250mW (300Ω) / 630mW (600Ω)
Asymmetrical headphone output power2500mW (100Ω) / 350mW (300Ω) / 175mW (600Ω)
crosstalk<-130dB
Power260W (3 transformers)
Various
Consumption95W (Class A)
Weight19kg
Housing material100% Aluminum
Dimensions430 x 450 x 125mm
Digital displayYes
AccessoriesPower cable / Remote control
InputACSS
InputXLR
OutputJack 6.35mm
OutputACSS
ClassClass A / AB
3 reviews
Toujours top avec du recul
Oui, 3ième avis!
Depuis l'achat en août je le découvre toujours dans le bon sens.
Ayant récemment amélioré ma chaîne, carte usb (Matrix Element H pour sortie PC vers dac achetée ici, top!), câble secteur Pangea AC9 mk2 au lieu d'un 14SE, et liaison RCA Neotech Nemoi 3220 pur cuivre entre dac et HE-9.
Le HE-9 continue à pousser ses qualités encore bien au-delà.
Pour l'instant je dirai surtout en mode préampli il va très loin! c'est beau, somptueux, incroyable.
This review has been posted for AUDIO-GD HE-9 Balanced Preamplifier / Headphone Amplifier ACSS RCA XLR
Superlatif
Suite de l’avis pour la section préampli.
C’est ce que j’ai eu de meilleur.
La définition très poussée, l’aigu doux, la spatialisation, le grave phénoménal, la séparation des plans en particulier dans le médium, la neutralité, la dynamique. Pour l’instant je ne vois aucun défaut dans la restitution, tellement elle est belle, classe, et le frisson est souvent là. Et ce n’est pas une somme de qualités simplement additionnées, il existe une homogénéité, une magie dans l’écoute, et en particulier dans la façon de spatialiser, le HE-9 a sa personnalité je pense (je l’ai lu concernant la section ampli casque, mais c’est vrai).
Après il y a les amateurs d’appareils à tubes, je ne dis pas que celui-ci qui est à transistors est le meilleur de tous, mais il est certainement excellent et je ne trouve pas qu’il soit spécialement froid.
Je me rends compte de l’importance du préampli sur un système, ce maillon s’il est de grande qualité apporte beaucoup.
exceptionnel
Le HE-9 est un appareil magnifique.
Il est gros et lourd.
Il ne faut pas le juger au premier branchement, le faire tourner un moment avant d'avoir un avis...
Sur sortie casque il vaut mieux l'utiliser sur la symétrique xlr, il ne donnera pas tout son potentiel sur jack asymétrique.
Avec un Hifiman HE-6 qu'il peut driver sans problème, même à fort volume, c'est une forme de nirvana.
Pas vraiment testé en mode préampli, je l'ai pris aussi pour ça.
Pour l'instant j'ai des petites Focal XS Book amplifiées, on sent que le préampli a un gros potentiel mais bientôt je testerai sur ma chaîne.
Je ne regrette absolument pas ce choix, ce HE-9 reste cher, mais sur des marques classiques combien faudrait-il mettre pour obtenir cette qualité sonore?
The HE-9 from Audio-GD, belonging to the HE range (evolution of the MASTER series) has benefited from an extended design time to lead to an...
