AUDIO-GD MASTER 19 Class A Balanced Preamplifier Headphone Amplifier ACSS
Audio-GD is back with its Master 19, a preamplifier and headphone amplifier featuring a symmetrical Class A architecture with totally discreet analog stages and ACSS circuits. It will easily integrate into any high-fidelity audio system, offering a high quality of sound reproduction marked by transparency and flawless precision.
By buying this product you get 105 loyalty points
Reference : 14198
1 050,00 €tax incl.
875,00 € tax excl.
Audio-GD Master 19
Préamplificateur Symétrique Amplificateur Casque Class A ACSS 9W 40Ω
Audio-GD Master 19 Préamplificateur Symétrique Amplificateur Casque Class A ACSS 9W 40Ω
Audio-GD is back with its Master 19, a preamplifier and headphone amplifier featuring a symmetrical Class A architecture with totally discreet analog stages and ACSS circuits. It will easily integrate into any high-fidelity audio system, offering high sound quality, transparency and precision.
Class A output stages
The Master 19 has 4 output stages, each element is paired before assembly so that no adjustment is required. These output stages integrate 4 pairs of 150W transistors operating in Class A. Thus, the balanced output has 4 times more power than an unbalanced output.
The Class A structure offers a high quality reproduction and allows, by the design of the Master 19, to offer an important energy reserve at the headphone output. The balanced outputs cancel out noise and distortion for an incredibly rich and clear sound.
Connectivity
The Master 19 offers both balanced XLR and unbalanced RCA connectivity, but also ACSS input and output. On the headphone outputs side, the device features an asymmetrical 6.35mm jack and a 4-pole balanced XLR on the front panel. All outputs of the Master 19 can be used at the same time.
The input channels of the Master 19 are individually shielded and those not in use are completely disconnected so that the audio signals are not affected by the connected equipment.
Power supply
The power supply stage of the Master 19 uses two transformers and 4 PSUs in pure Class A to independently power the audio, control and display circuits. These PSUs Class A connected in parallel have a very high impedance to prevent the pulses from affecting the preamplifier and output stages.
Volume control
Unlike conventional volume controls using simple potentiometers, the Master 19 consists of a 4-channel relay attenuator using high-precision film resistors and relays with gold plated contacts. This system uses an I/V conversion in which the output corresponds to the current and not the voltage. This operation maintains a flat frequency response and never alters sound quality at any volume level.
The quality of the volume control is all the more important in a symmetrical architecture like that of the Master 19 in order not to create distortion. The volume control of the Master 19 is done on 100 steps with an attenuation range of 90dB. It has an exponential curve and allows precise adjustment of the volume level.
Adaptive impedance
The many DACs available on the market have different architectures and therefore a variable output impedance depending on the model. To avoid possible effects on sound quality due to different output impedances of the DACs, the Master 19 has 4 FET Class A input buffers on board. All input signals pass through these FET buffers, lowering the impedance to a very low level, regardless of the source's output impedance.
Metal remote control
The Master 19 is also delivered with a robust and stylish Aluminium remote control. This allows simple and remote access to basic functions such as volume control or source selection.
Technical specifications
Product typePreamplifier
Headphone amplifier
Inputs2x Single-ended RCA
2x Balanced XLR
1x ACSS
Outputs1x Single-ended RCA
1x Balanced XLR
1x ACSS
1x Single-ended Jack 6.35mm headphone output
1x Balanced XLR 4 poles headphone output
SNR> 130dB
THD< 0.003%
THD+N< 0.005%
Adjustable gainLow : +16dB (XLR)
High : +25dB (XLR)
Headphone output power (balanced, Class A)9000mW @ 40Ω
3800mW @ 100Ω
1250mW @ 300Ω
175mW @ 600Ω
Headphone output power (single-ended, Class A)2500mW @ 40Ω
1050mW @ 100Ω
350mW @ 300Ω
175mW @ 600Ω
Preamplifier output levelRCA : 10V
XLR : 20V
ACSS : 2.4+2.4MA
Output impedance1Ω
Input impedanceXLR : 90kΩ
ACSS : < 10Ω
Frequency response (XLR input)20Hz - 20kHz (+/-0dB)
1Hz - 220kHz (+0dB, -3dB)
Crosstalk> 130dB
Supply voltage220-240V AC 50/60Hz
Consumption45W
WeightApprox. 7kg
Dimensions360 x 360 x 85mm
Package1x Audio-GD Master 19
1x Metal remote control
1x Power cable
InputXLR
InputACSS
OutputACSS
OutputJack 6.35mm
ClassClass A / AB
Remote ControlYes
6 reviews
Soundstage monster
This has one of the biggest soundstages iw heard. Also instrument separation is far superior to almost any THX AAA based AMP.
BLACK background, sounds just happen all around you.
BUT needs absolutely top notch DAC to get most out of this.
This review has been posted for AUDIO-GD MASTER 19 Class A Balanced Preamplifier Headphone Amplifier ACSS
Un must au rapport qualité/prix redoutable ! !
Je utilise ce pré Audio GD Master 19 depuis env 2 mois mais je voulais prendre du temps avant de poster un avis sûr.
Que dire d'autre que:
Formidable préamplificateur !
Rapport qualité/prix difficilement, voire impossible à dépasser !
Réalisation audiophile et qualitative au top !
Très bien fabriqué, mise en œuvre et finition sans rapport avec le coût.
Tous les Know-How et astuces audiophiles réellement efficaces sont bien présents ici et l'on sent que les concepteurs connaissent ce qui permet de bien "sonner".
Je confirme aussi que cet appareil se bonifie durant premières 80 à 100 heures. (Rodage)
En tant que qu'ex pro et ex journaliste de revues hifi j'en ai possédé une bonne vingtaine dont des plus réputés; et bien ce préamplii ligne est comparable aux meilleurs voire même mieux que la plupart vu entre autres l’extrême soin apporté aux étages de sortie ici en pure classe A sans contre-réaction. Rare et exceptionnel sur le plan de la musicalité (même si moins "éclatant" aux mesures"); et... cela s’entend vraiment.
Sa neutralité et sa transparence sont exceptionnelles et à même de révéler la faiblesse des autres maillons !
Si les éléments périphériques autour du Master 19 évoluent, (ampli, enceintes, source), il suit en confirmant ses performances ; il ne semble limité que par la faiblesse éventuelle des autres maillons. "C
"Cerise sur le gâteau: Audiophonics le livre avec une superbe télecommande en métal massif qui est ailleurs optionnelle à plus de 50 €.
Bravo !
PS: Je ne suis pas payé par Audio-GD
HAUTEMENT RECOMMANDE !
CB
Un bon achat
C'est un amplificateur de fabrication robuste qui me donne entière satisfaction.
Je l'utilise avec un DAC R-2R, Pegasus, et un streamer, l'Allo USBridge Signature. Je branche à sa sortie symétrique une variété de casques.
Master 19 est un amplificateur puissant et il drive aisément des casques d'impédance élevée et des planars.
C'est aussi un bon préamplificateur. Sa télécommande est très pratique à l'usage.
Je remercie M. David Aubert pour ses bons conseils lors de l'achat.
PUISSANCE, DOUCEUR, TRANSPARENCE ET SILENCE!
Je souhaite compléter mon avis du 15/12/2020 suite à l'utilisation d'un câble XLR4 à la place du 6.35, avec mon casque Kennerton Thekk. En effet, ce branchement en symétrique a fait totalement disparaître le "hum" (petit bruit de fond sourd, type bruit de vieux transformateur électrique), qui se produisait "à vide" (sans musique).
Merci à Audiphonics d'avoir pris le temps de vérifier ce souci sur un appareil en stock, et de m'avoir recommandé une solution efficace et répondant au souci.
L'écoute est désormais vraiment au top avec mon Thekk: cet ampli me semble globalement d'un très haut niveau, surtout en regard de ce prix!
J'ai la nette impression que le branchement en tout symétrique (en entrée depuis le dac et en sortie vers le casque) a "ouvert" l'écoute, et la sublime complètement! Il n'y a aucun crispation, c'est transparent, neutre mais pas du tout sec, froid, chirurgical: il y a beaucoup d'élégance, beaucoup de matière dans les timbres difficiles comme le violon ou le piano. A côte de cela, la dynamique est vraiment incroyable et dépasse celle de mon Sugden Masterclass HA4!
C'est tout simplement magnifique à mes oreilles :-) !
PUISSANCE, DOUCEUR et TRANSPARENCE
Voilà quelques semaines que mon Master19 "tourne" tous les soirs, à raison d'une ou deux heures à chaque fois, exclusivement pour alimenter mon casque orthodynamique Kennerton Thekk (et ponctuellement un très modeste AKG K702 par curiosité). L'ampli est alimenté via les XLR par un dac RME ADI2 FS, lui même alimenté par un streamer SOTM SMS200 Neo qui reçoit un flux issu soit de Qobuz soit de mon NAS Synology. Le tout est connecté avec des câbles blindés Pangea. Pour le moment mon Thekk est connecté en asymétrique au Master19 via la 6.35.
Je ne vais pas rentrer dans les détails et vais essayer d'être synthétique, sachant que mes 2 amplis sédentaires que j'ai en parallèle et qui me servent ici de référence sont un Sugden Masterclass HA4 et l'ampli du RME ADI2 FS. Donc ce qui prédomine à mes oreilles avec ce Master19 c'est une grande douceur générale, qui je crois est assez typique des VRAIS appareils ClassA (comme mon Sugden). Le rendu, sur l'ensemble du spectre est pleine de matière, organique et douce, voire suave. On est à l’opposé du rendu de l’ampli du RME ADI2, qui lui est très sec, chirurgical, hyper détouré mais sans élégance, et peut même devenir fatigant bien que mon casque ne le soit pas du tout. Ce que j’entends également, c’est un très grand équilibre général avec le Master19 et mon Thekk. Je ne ressens pas une mise en avant d’une partie d’une spectre, ou au contraire un retrait d’une autre. Tout semble a sa place, c’est transparent. Cette électronique me semble retranscrire fidèlement les scènes sonores que j’ai écouté, avec beaucoup d’espace dans les 3 dimensions. Les timbres que je connais bien me sont apparus très réalistes, et très beaux. Les voix sont absolument superbes, autant les voix féminines que les voix masculines. Alors que l’ampli du RME laisse facilement entendre des “tssssss” et autres sifflements pas très agréables, le Master19 donne beaucoup plus de matière. Finalement, cet ampli ne s’éloigne pas tant de mon Sudgen, mais je crois qu’il apporte un petit plus d’espace dans les scènes sonores, et encore plus matière sur les voix.
Alors sur l’appareil lui-même, vu de l’extérieur ça respire le sérieux, la solidité. C’est un ampli qui progressivement chauffe fort. Au bout de 2 ou 3 heures, la surface atteint les 40°C. Il semble avoir une forte réserve de puissance, un peu comme mon Sugden dont la puissance n’est pas annoncée par le fabricant. Mais difficile de comparer les 2 amplis car les 2 potentiomètres ne fonctionnent pas de la même façon (celui du Master19 n’est pas linéaire). Avec mon Thekk qui est à 100dB et 35Ohm, en gain faible, j’écoute autour de 55 (sur 99), ce qui donne un niveau d’écoute déjà assez “confortable”. La précision du réglage du volume est excellente. Le cliquetis des relais du système de potentiomètre est curieux, mais pour moi pas gênant.
J’ai tout de même un reproche ou un souci à signaler: avec mon Thekk, un “hum”, un bruit de fond à peine audible, est perceptible à vide. C’est une sorte de bruit de transformateur, indépendant de mon installation tant audio qu’électrique. Audiophonics a constaté ce phénomène également sur un casque à faible impédance lorsque j’ai signalé le souci au SAV. J’ai fait de mon côté des essais avec des IEM à très faible impédance: le bruit est effectivement encore plus fort qu’avec mon Thekk qui fait 35Ohm. Mon K702 qui fait 62Ohm n’émet aucun “hum”. La solution, d’après Audiophonics, serait une connexion du casque en XLR. J’ai donc commandé un cable symétrique XLR que j’attends. Je referai un retour ici une fois les essais réalisés, en croisant les doigts pour que ce léger défaut lié à l’impédance faible de mon casque disparaisse en symétrique.
Audio-GD is back with its Master 19, a preamplifier and headphone amplifier featuring a symmetrical Class A architecture with totally discreet...
