AUDIO-GD MASTER 9 MK3 Balanced Headphone Amplifier / Preamplifier Pure Class A Silver
With the Master 9 MK3, Audio-GD presents the latest version of its headphone preamplifier/amplifier. This model builds on the success of its predecessor, still being a dual mono Class A headphone amplifier. With this new iteration, Audio-GD has mainly worked on the miniaturisation of its amplifier, going from a 16kg model to a 7kg model, without making any concessions to the quality of sound reproduction.
By buying this product you get 125 loyalty points
Reference : 19259
1 259,00 €tax incl.
1 049,17 € tax excl.
Shipping date: 11-06-2026.
AUDIO-GD MASTER 9 MK3 : Front view
With the Master 9 MK3, Audio-GD presents the latest version of its headphone amplifier/preamplifier. This model builds on the success of its predecessor, still being a dual mono Class A headphone amplifier. With this new iteration, Audio-GD has mainly worked on the miniaturisation of its amplifier, going from a 16kg model to a 7kg model, without making any concessions to the quality of sound reproduction.
Audio-GD Master 9 MK3 : Gain control
The Master 9 MK3 incorporates a gain adjustment function, making it easy to adapt to any type of headphone, even the most difficult to drive.
- The "L" (Low) mode has a gain of 16dB, making it suitable for powering headphones with a sensitivity of even more than 100dB, or for use as a preamplifier.
- The 'H' (High) mode has a gain of 25dB, enabling headphones with a sensitivity of between 80 and 100dB to be powered.
Audio-GD Master 9 MK3 : Quality power supply
The Master 9 MK3 has a dual mono architecture, so the right and left channels each benefit from an R-core transformer and 4 dedicated Class A power supply modules. The Class A modules used have a very high input impedance to prevent impurities from passing through the block and affecting the preamplifier, and a low output impedance, high speed and high linearity. The result is a very clean power supply with virtually no impact on the final sound reproduction.
AUDIO-GD MASTER 9 MK3 : Inside view
Audio-GD Master 9 MK3 : A design without compromise
The output stage uses a diamond structure for its circuit. This particular structure uses 4 transistors in a configuration reminiscent of a diamond crystal if represented schematically, it has the dual advantage of being fast and accepting high loads. Four 150W transistors are used per channel, operating in pure Class A. As a reminder, Class A amplification has the particularity of having its active components always in conduction. As a result, they amplify the input signal in its entirety, greatly limiting the total rate of harmonic distortion at the output. And so, thanks to its diamond structure and Class A operation, the Master 9 MK3 has signal processing that's both fast and distortion-free, for a result of rare quality.
Audio-GD Master 9 MK3 : Innovative volume control
The 100% discrete design of this amplifier (no OPA) is supported by a volume control that differs from conventional methods. Traditionally, volume control takes place in the input stage of the amplifier via a potentiometer to reduce the signal. The main problem with this method is that the quality of the potentiometer has a direct impact on the quality of the sound, which can easily lead to a loss of detail, channel imbalance or distortion that will later be amplified. So even with a quality potentiometer, its impact on the signal-to-noise ratio can be felt. To address this problem, Audio-GD uses an I/V converter located in the output stage of the Master 9 MK3. The task of this converter is to transform the signal current into voltage, so volume control depends on the conversion rate applied. This solution has a twofold advantage: firstly, it operates at the output stage, so has no impact on signal processing; secondly, the integrity of the original signal is preserved, since control is via a converter and not a resistor.
Audio-GD logo with ACSS mention
Audio-GD Master 9 MK3 : ACSS connectivity
Finally, the Master 9 MK3 is equipped with ACSS output. This is a proprietary technology of the brand called ACSS for Audio-GD Current System Signal. Thanks to the company's expertise and know-how, this technology offers a less coloured, more detailed sound with unrivalled neutrality. When the ACSS output is used, the XLR and RCA outputs switch to mute mode.
AUDIO-GD Master 9 MK3 remote control
The Master 9 MK3's remote control not only controls the preamplifier/headphone amplifier, but also an external Audio-GD DAC, if you wish to pair one with the Master MK3.
Audio-GD Master MK3 remote control
1Mute mode
2Preamplifier Auto dim
3Input source selection
4Gain
5Volume control
6DAC controls
Product typeHeadphone Amplifier / Preamplifier
Inputs1x Stéréo RCA
2x XLR 3-pin stereo
1x ACSS stereo
Ouputs1x Stéréo RCA
1x XLR 3-pin stereo
1x ACSS stereo
1x Headphone output 6.3mm Jack
1x XLR 4-pin headphone output
Signal-to-noise ratio (SNR)> 130dB
Total harmonic distortion (THD)< 0.003%
Volume control100 step, exponentiel
Balanced headphone output power9000mW @ 40Ω
3800mW @ 100Ω
1250mW @ 300Ω
630mW @ 600Ω
Single ended headphone output power2500mW @ 40Ω
1050mW @ 100Ω
350mW @ 300Ω
175mW @ 600Ω
Preamplifier output level (max)RCA : 10V
XLR : 20V
ACSS : 2.4+2.4MA
Output impedance1Ω
Input impedanceXLR : 90KΩ
ACSS : < 10Ω
Frequency response20Hz - 20kHz @ +/-0dB
1Hz - 220kHz @ +0dB, -3dB)
Crosstalk> 130dB
GainLow Gain : +16 DB (XLR)
High Gain : +25DB (XLR)
Consumption45W
Weight7kg
Dimensions360 x 290 x 75mm
Housing materialAluminum
ColorSilver
Package1x Audio-GD Master 9 MK3
1x Power cable
1x Remote control
InputACSS
InputXLR
OutputJack 6.35mm
OutputACSS
ColorSilver
ClassClass A / AB
Remote ControlYes
2 reviews
Pol
Un produit exceptionnel pour son prix
This review has been posted for AUDIO-GD MASTER 9 MK3 Balanced Headphone Amplifier / Preamplifier Pure Class A Silver
Game changer
I’m not usually one to leave reviews, but this Master 9 MK3 truly deserves it.
At the moment, I’m using it as a preamplifier in a fully balanced audio chain. It’s heavy and really does consume 40W!
I’ve completed the recommended 300 hours of burn-in and always wait until it’s nicely warmed up before judging it. It gets quite warm, operating at around 45°C.
The sound is incredible… 16-bit 44.1 kHz music is transformed, and now, with well-recorded tracks, I can no longer clearly perceive a difference compared to 24-bit music! I know it sounds unbelievable, but that’s how it is! The music loses that digital flavor while still remaining extremely detailed. The sound is open, dynamic, yet smooth and never fatiguing. That’s the magic of Class A! A very capable and refined preamplifier with excellent volume control.
With the Master 9 MK3, Audio-GD presents the latest version of its headphone preamplifier/amplifier. This model builds on the success of its...
