AUDIOPHONICS JC2-FET Preamplifier Volume Control Source Selection
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these circuits operates in pure Class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and maintain full signal precision.
4.6 / 5
By buying this product you get 36 loyalty points
Reference : 14774
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 23-04-2025.
Preamplifier - Volume control - 4x input source selector - Class A double linear power supply
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these circuits operates in pure Class A and is powered by its own regulated linear power supply to provide extremely clean channel separation and maintain full signal precision. Each of the channels is driven by JFET K170BL / J74BL.
The JC2-FET has an elaborate analog circuit with separate  pre-amplified channels fed separately with a combo of toroidal transformers. It offers volume control via a rotary potentiometer located on the front panel.
The device also offers a source selection function on its 4x stereo inputs (RCA connectors) mounted on its rear panel.
The source selection is made using a rotary selector located on the front panel.
The rear panel includes all input and output connectors to allow clean and tidy wiring. The analog output is available on a stereo RCA connector and will thus be able to work with most of your amplifier models.
There is also the power connector (IEC) designed for 220V voltages.
TypePreamplifier
Source selector
Inputs4x RCA stéréo
Outputs1x RCA stéréo
Frequency response20Hz-45kHz
Input sensitivity2V RMS
Output level9V RMS
Output impedance100 Ohm
Gain13dB
SNR103dB
Dimensions330 x 62x 308mm
Weight4.2kg
Power SupplyLinear regulated
AC220V (Power cable NOT included)
ColorSilver
ClassClass A / AB
9 reviews
Expectations confirmed.
I.m founding this preamp excellent in order quality construction and sound. It's very close and somewhat superior respect to my EC1 pre Electrocompaniet.
Quality sound improves noticeably after at least 100 hour and more burn-in (in the beginning is not too great).
I'm gonna replace output solen caps with better Janzten z cap superior.
Item arrived quickly in a few days, thanks to Audiophonics.
This review has been posted for AUDIOPHONICS JC2-FET Preamplifier Volume Control Source Selection 4x RCA
I took about 100hour.
From the begining this preamp work and sounded well, but after approximately 100hour it was blooming. The sound widened, instruments found there right places on the recording. Paring it with audiophonics purifi, sparkos power amplifier.
Excellent
Je recherchais un préampli aux fonctionnalités simples (volume et sélecteur de source point barre), neutre, musical, de (très) bonne qualité de fabrication, à un prix très accessible pour driver un ampli DIY LFA-50 Optim-A dont je viens de faire l'acquisition. Ce préampli remplit parfaitement ce cahier des charges.
Ce préampli, preuve de sa neutralité, est très sensible aux câbles de modulation utilisés. en possédant plusieurs non utilisés, je me suis amusé à faire différents essais : les différences sont clairement audibles (couleur, définition, équilibre général, largeur et profondeur de la scène sonore).
J'ai donc fait le choix de lui associer des câbles de modulation et d'alimentation de qualité. En entrée du préampli j'utilise un câble argent de chez Audiocadabra (relié à un dac Gustard 20H) et en sortie du préampli un câble OYAIDE TUNAMI TERZO RR (vendu sur ce site). Pour l'alimentation, je n'ai pas hésité également à lui associé un câble FURUTECH The Empire E (également vendu sur ce site).
Les résultats à l'écoute dépassent largement mes attentes. Le rapport / qualité de ce préampli est imbattable. Il mérite des câbles de qualité.
Merci à Audiophonics pour la qualité des produits proposés et à l'efficacité et gentillesse de son équipe.
Excellent préampli solid state.
Ce JC2-FET semble remplacer l'ancien préampli Audiophonics solid state, noir, appelé JC2 par beaucoup et doté seulement de 3 entrées et qui a d'ailleurs récemment disparu du catalogue Audiophonics.
Et bien que dire du nouveau JC2-FET, de ce nouvel arrivé?
Il chauffe un peu, plus que l'ancien préampli noir, ce qui n'est pas un mauvais signe.
Tout d'abord, que les qualités du nouveau venu semblent bien supérieures à l'ancien, lequel en donnait déjà beaucoup pour 170€. Ici la différence de prix s'entend clairement. Plus de précision, de matière, de relief, les timbres sont d'une plus grande richesse, la transparence fait un bond étonnant. Mais cela ne serait rien si la musicalité, l'expressivité n'avait pas suivi cette progression. Et bien, elle est clairement plus évidente, les voix d'un opéra de Rameau, par exemple, nous interpellent, elles ne sont pas que de simples exercices stériles de style, leur humanité nous bouleverse tout simplement.
Ce préampli m'a conquis mais cela a pris du temps.
Tout d'abord, il réclame un rodage de plusieurs semaines, donc trés long, je préviens les pressés.
Ensuite, il est très sensible aux câbles de modulation, en amont j'ai mis un Van den Hul First qui lui va trés bien, en mettant en valeur la délicatesse du rendu sonore qui nous est offert, pour un prix assez démocratique.
Et puis il est trés sensible à l'ampli de puissance placé en aval: un Quad 606 est servi aux petits oignons avec ce JC2-FET alors qu'un Goldmund n'y fait pas des étincelles, mais cela ne m'étonne pas, Goldmund a toujours été un peu atypique.
Bref ce préampli offre une transparence assez incroyable mais il sert aussi vraiment la musique et ne fait absolument aucune chirurgie sonore.
Je cherchais un préampli solid state pouvant atteindre les qualités musicales d'un bon ampli à tubes et je crois bien avoir atteint mon but.
5 étoiles oui, mais.........
Raccordé soit à ampli transistorisé ou à tubes, fait entendre soit de la ronfle soit des bruits bizarres en absence de modulation suivant position du potentiomètre. La solution a été de mettre un transfo pour supprimer la boucle de masse. Plus de bruit, très bon son.
Un bon transfo coûte aussi cher que le préampli lui-même. Dommage que ce point n'ait pas été mieux traité.
Nous avons détecté le soucis sur certaines unités, nous avons apporté une modification pour le corriger.
This neatly designed preamplifier & source selector (4 inputs) has two separate circuits for each channel of the stereo signal. Each of these...
