DENAFRIPS HADES 12TH Discrete Balanced Preamplifier Black
Elevate your audio experience with the Denafrips Hades preamplifier, a masterpiece born of uncompromising dedication to audio perfection. Designed for the discerning audiophile, the Hades is the pinnacle of technical precision and sonic sophistication.
By buying this product you get 156 loyalty points
Reference : 19177
1 560,00 €tax incl.
1 300,00 € tax excl.
Denafrips Hades 12TH Discrete Balanced Preamplifier Pure Class A Black
Denafrips Hades 12th : Vue de face
Developed and manufactured with precision and care, the Hades benefits from a pure Class A line stage that is entirely discrete and totally balanced.
Its microprocessor-controlled 60-step attenuator with precisely matched resistors guarantees perfect channel balance and extremely low distortion, measured at just 0.00023%. The result is a sound of incredible purity, clarity and precision.
All Hades components are housed in a sturdy, modern aluminum chassis. It also features a front-panel display to show the selected volume level.
Key features:
  • Pure class A. True balanced, discrete, high-quality line stage
  • Microprocessor-controlled 60-step relay volume attenuator
  • High-precision resistors and components throughout with perfect channel balance and low distortion
  • Remote control
Denafrips Hades 12TH : Vue interne
Denafrips Hades 12TH : Connectors
Denarfips Hades 12TH : Connectique
1Balanced XLR inputs
2Single-ended RCA input
3Balanced XLR output
4Single-ended RCA output
Product typeDiscrete balanced preamplifier
ArchitecturePure classe A
AttenuatorMicroprocessor-controlled 60-step relay attenuator
Inputs2x XLR stereo balanced
1x RCA stereo single-ended
Outputs1x RCA stereo single-ended
1x XLR stereo balanced
Input impedanceSingle-ended: 12.2kΩ
Balanced: 60kΩ
Output levelRCA: 2Vrms
XLR: 4Vrms
Output impedanceUnbalanced: 200Ω
Balanced: 400Ω
GainUnity gian, 0dB
Frequency response10Hz - 85kHz (-0.3dB)
THD+N0.00045%
SNR122dB
Dynamic range> 121dB
Crosstalk-110dB
Supply voltage100-240VAC 50/60Hz
Consumption25W
Dimensions320 x 380 x 80mm
Weight9kg
Package1x Denafrips Hades 12TH
1x Remote control
InputXLR
ClassClass A / AB
Remote ControlYes
DENAFRIPS HADES 12TH Discrete Balanced Preamplifier Pure Class A Black
Elevate your audio experience with the Denafrips Hades preamplifier, a masterpiece born of uncompromising dedication to audio perfection. Designed...
