DENAFRIPS 12TH Preamplifier Silver
With the Hestia 12TH, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure Class A to deliver unprecedented sound quality. Its microprocessor-controlled 60-step attenuator with precision-tuned resistors ensures perfect balance between channels and an incredibly low harmonic distortion level of just 0.000230%, giving you the most crystal-clear sound possible.
By buying this product you get 123 loyalty points
Reference : 19874
1 230,00 €tax incl.
1 025,00 € tax excl.
Denafrips Hestia 12TH Discrete Balanced Preamplifier Pure Class A Silver
Denafrips Hestia 12TH : Front view
Denafrips Hestia 12TH: attenuator and class A
Denafrips Hestia 12TH : Tailor-made power supply
The power supply stage has also received special attention. The Hestia 12TH benefits from a O-Core copper OCC transformer with shielding to protect it from any external electromagnetic interference. Furthermore, the power supply has been fitted with a host of low-noise linear power capacitors to ensure that the power supply is both stable and perfectly silent.
Denafrips Hestia 12TH : Power supply
Denafrips Hestia 12TH : Seamless integration into your setup
With its two balanced inputs and one balanced output, the Hestia integrates perfectly into any audio installation, whether it's a professional studio or an audiophile-quality setup. Its adaptive nature and compatibility ensure seamless integration into your existing setup, enhancing overall performance and delivering an incredibly wide and immersive soundstage.
Product typeDiscrete balanced preamplifier
ArchitecturePure classe A
AttenuatorMicroprocessor-controlled 60-step relay attenuator
Inputs2x Balanced stereo XLR
1x Single-ended stereo RCA
Outputs1x Balanced stereo XLR
Input impedanceBalanced : 60kΩ
Single-ended : 12.2kΩ
Output levelRCA : 2Vrms
XLR : 4Vrms
Output impedanceBalanced : 400kΩ
Single-ended : 200Ω
GainUnity gain, 0dB
Frequency response10Hz - 80kHz (-0.3dB)
Total harmonic distortion more noise (THD+N)0,000230%
Signal-to-noise ratio (SNR)120dB
Dynamic range>121dB
Crosstalk-110dB
Supply voltage100-240V AC 50/60Hz
Consumption20W
ColorSilver
Dimensions320 x 330 x 60mm
Weight6.5kg
Package1x Denafrips Hestia 12TH
1x Remote control
InputXLR
ColorSilver
ClassClass A / AB
Remote ControlYes
With the Hestia 12TH, Denafrips presents a balanced preamplifier based on 100% discrete components operating in pure Class A to deliver...
