FX-AUDIO TUBE-01 Valve 6J1 Stereo preamplifier Black
The 6J1 FX-Audio TUBE-01 tube buffer preamplifier is a smart little tool to improve the sound of a desktop DAC or HiFi installation. With a gold-plated stereo input and output, it will be a quality companion coupled with a Class D power amplifier.
4.9 / 5
Reference : 10995
29,90 €tax incl.
24,92 € tax excl.
FX-Audio Tube-01
Préamplificateur à Tubes 6J1 Stéréo Noir
FX-Audio Tube-01 Préamplificateur à Tubes 6J1 Stéréo Noir
The 6J1 FX-Audio TUBE-01 tube buffer preamplifier is a smart little tool to improve the sound of a desktop DAC or HiFi installation. With a gold-plated stereo input and output, it will be a quality companion coupled with a Class D power amplifier to restore dynamics and sound to any installation that lacks liveliness. At the proposed price, this device has qualities that are usually absent in this category.
Moreover, this preamplifier does not have the caricatural sound of the classic low-midrange tube productions. On the contrary, the terms transparency, dynamics, musical delirium, sound matter are the ones that immediately come to mind. An excellent introduction for any enthusiast looking for an affordable, high quality tube preamplifier.
This preamplifier has a high gain, so it will boost a slightly low source. When using a fixed 2V source, the volume knob can be very sensitive, the gain of 1 being obtained in the first third of the potentiometer stroke.
Product typeTube preamplifier
Output voltage2000mV
Impedance600 Ohm
SNR100dB
Input sensitivity300mV - 2000mV
Distortion1000mV, 0.1%
Input1x Stereo RCA (Gold plated)
Output1x Stereo RCA (Gold plated)
Compatible tubesEF95
6AK5
Power supply12VDC 1A via Jack DC 5.5/2.5 (power supply included)
DimensionsW 100 x L 95 x H 32mm (65mm with tubes)
Weight480g
Color
  • Black
Class
  • Tube amp
Input
  • RCA
Output
  • RCA
Remote Control
  • No
20 reviews
TB mais pas parfait avec équipement natif
Converti à la préamplification à tubes par un intégré hybride 'Qinpu Q2', je souhaitais pour mon système principal (salon) acquérir un préamplificateur séparé et lui adjoindre un ampli de puissance. J'ai opté pour ce 'petit' FX-AUDIO en me fiant aux commentaires des précédents acquéreurs. Après installation initiale, le tout 1er essai fut peu convaincant car les tubes d'origine étaient manifestement défectueux. Ceci étant, n'ayant pas l'intention de les garder, j'avais pris soin de commander aussi une paire de tubes GE 5654 et le rendu a changé du tout au tout. Depuis, j'ai trouvé des 'Mullard CV4010 UK' qui sonnent encore mieux : plus de clarté et de précision, tout en conservant la rondeur du tube. Il me reste encore à remplacer le potentiomètre d'origine par un Log et tout sera parfait ! J'enlève cependant une étoile à cause des tubes et du potentiomètre d'origine qui obligent à 'mettre les mains dans le cambouis'.
This review has been posted for FX-AUDIO TUBE-01 Valve 6J1 Stereo preamplifier Black
Vraiment bien !
Pressé de recevoir ce préampli pour essayer mon nouveau gros bloc à tubes, vraiment pas déçu.
Ce serait un comble que mon nouveau preamp à tubes HDG ne soit pas mieux sachant qu'il coûte 40 fois plus cher.
A 30 euros ce préampli est une bonne solution pour test.
La diode rouge sur le bloc de la prise secteur est un phare la nuit, un détail.
Livré en 24 heures chrono après une modif de commande, la version argent-silver n'étant finalement pas dispo, je l'ai eu en noir, vu ce que je vais en faire...
Top Audiophonics, comme d'hab !!! Merciiiiiii.
Génial !
Ce petit machin est tout simplement génial !
Je profite pour vous remercier tout est parfait ! Envoi rapide et bien emballé .
La communication est excellente, merci
Christian
Excellent preampli très peu coûteux
J'avais laissé un avis concernant l'utilisation du fx-audio tube 01 en tant que buffer puisque le gain était totalement inadapté pour l'utiliser comme preampli branché sur la section ampli de mon Nad c326.
En réalisant un pont diviseur avec une résistance 47 kohms série et une 1.5 kohms parallèle , sur chaque canal en entrée de l'ampli de puissance,
les résultats sont excellents.
Réglage du volume très fin, scène sonore très large et aérée, belle matière, effet stéréo important, bon équilibre tonal ,relief et vivacité ainsi qu'un petit côté envoûtant...
Service Audiophonics impeccable.
The 6J1 FX-Audio TUBE-01 tube buffer preamplifier is a smart little tool to improve the sound of a desktop DAC or HiFi installation. With a...
