Tube Preamplifier 2x 6N3 DAC ES9018K2M CM6642 Subwoofer 24bit 192kHz
The FX-Audio TUBE-06 MKII is an affordable and efficient tube preamplifier. Its preamplifier stage is based on the use of a pair of 6N3 tubes. It is associated with a digital/analog conversion section using an ESS ES9018K2M DAC chip, a CM6642 USB interface or other quality components such as NE5532 and OPA2134 AOs. It is thus capable of a musical and warm restitution. It also supports audio streams up to PCM 24bit 192kHz.
Practical, its front panel is equipped with both a volume control, but also adjustments to adapt the bass and treble levels. It also benefits from a complete connectic with USB-B, Optical and RCA stereo input, and RCA stereo output as well as a subwoofer output.
Product type | Preamplifier |
Tubes | 2x 6N3 |
DAC Chip | ES9018K2M |
USB Interface | CM6642 |
Inputs | 1x USB-B 1x Optical Toslink 1x Stereo RCA |
Outputs | 1x Stereo RCA 1x Subwoofer output (RCA) |
Microcontroller | STM8s |
AOP | NE5532 OPA2134 |
Supported sampling rates | PCM up to 24bit 192kHz |
Line output level | 3Vrms |
THD+N | < 0.5% |
Frequency response | 20Hz-20kHz |
SNR | 98dB |
Supply voltage | 12VDC 2A |
Housing material | Aluminum |
Dimensions | 133 x 179.2 x 35.7mm |
Color | Silver |
Package | 1x FX-Audio Tube-06 1x Power supply 1x USB cable |
Input | USB |
Input | Optical |
Input | RCA |
Output | RCA |
Output | Subwoofer |
Color | Silver |
Class | Tube amp |
Remote Control | N/A |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
