FX-AUDIO TUBE-06 Tube Preamplifier with Tone Control 2x 6N3 DAC USB Black
FX-AUDIO TUBE-06 Tube Preamplifier with Tone Control 2x 6N3 USB Black
The FX-Audio TUBE-06 is a 6N3 tube preamplifier. Offered at a low price, it remains a very good preamplifier, complete and powerful, with its own volume control. It thus integrates, in addition to the classic RCA Stereo and 3.5mm Jack inputs, a USB-B input to connect your computer or phone.
Reference : 13461
85,00 €tax incl.
70,83 € tax excl.
This product has been replaced by the new version, the FX-AUDIO TUBE-06 MKII Tube Preamplifier 2x 6N3 DAC ES9018K2M.
FX-Audio TUBE-06
FX-Audio TUBE-06 Préamplificateur à Tubes avec Contrôle de Tonalité 2x 6N3 USB Noir
The FX-Audio TUBE-06 is a 6N3 tube preamplifier. Offered at a low price, it remains a very good preamplifier, complete and powerful, with its own volume control. It thus integrates, in addition to the classic RCA Stereo and 3.5mm Jack inputs, a USB-B input to connect your computer or phone. The DAC for digital-to-analog conversion is directly integrated into the CM6533 USB interface and allows decoding of the quality signal. On the output side there is a Stereo RCA. All connectors are gold plated, ensuring very good conductivity and resistance to oxidation. Finally, there is a tone control on the front panel, which allows you to adjust the bass and treble reproduction according to your listening and audio system.
Product typeTube preamplifier
Inputs1x USB-B
1x Stereo RCA
1x Jack 3.5mm
Output1x RCA
Tubes2x 6N3
THD0.02%
SNR-110dB
Frequency response20Hz - 20kHz (+/-2dB)
Tone controlBass / Treble
Max USB DAC Sampling rate24bit 96kHz
Power supply12V 1A via Jack DC 5.5/2.1mm (power supply included)
Dimensions130 x 140 x 75mm
Weight560g
Package1x FX-Audio Tube-02
2x 6N3 Tube
1x Power supply
1x USB Cable
InputJack 3.5mm
Super rapport qualité/prix
Ce petit pré-ampli sans prétention est une aubaine à ce tarif.
D'origine, il est déjà excellent mais montez dessus deux tubes NOS 6N3P-DR et une alim à faible bruit et vous obtenez une petite bombe musicale.
J'ai testé le dac par curiosité (câble usb fourni), il fonctionne bien, reconnu de suite sous Windows 10 et sans drivers.
Il est moins performant que celui de mon Topping DX3 Pro mais il n'y a pas un gouffre non plus.
Autre remarque importante, ce pré-ampli est vraiment silencieux, tout juste un très léger souffle si l'on colle l'oreille au tweeter sur des enceintes à 90db.
La fabrication n'est pas en reste, c'est plutôt qualitatif, boitier en aluminium de bonne qualité, les boutons sont crantés et n'ont pas de jeu.
Le seul point négatif me concernant est le potentiomètre de volume qui est trop sensible avec ma configuration. Au bout de 3 crans, je suis déjà à volume important. Peut-être prévoir un changement de celui-ci pour un model 50K logarithme à l'avenir...
This review has been posted for FX-AUDIO TUBE-06 Tube Preamplifier with Tone Control 2x 6N3 DAC USB Black
The FX-Audio TUBE-06 is a 6N3 tube preamplifier. Offered at a low price, it remains a very good preamplifier, complete and powerful, with its own...
