HATTOR AUDIO THE BIG Balanced Passive Preamplifier Vishay SMD Black
By buying this product you get 104 loyalty points
Reference : 14271
1 049,00 €tax incl.
874,17 € tax excl.
HATTOR Audio Preamplifier 10k
Preamplifier / motorized balanced passive attenuation
motorized passive preamp Hattor Audio
This superb passive preamplifier carries two SMD resistors (1% accuracy) and offers among the best refinements in sound reproduction.
The device is both a preamplifier and a source selector with large connectivity (2x RCA & 3x XLR IN / 2x RCA & 2x XLR OUT). The device is assembled by hand and both its inner circuitry and outer housing have a near-perfect finish. Hattor Audio attenuator truly is part of choice in any advanced ambitious Hi-Fi installation.
Resistors Vishay SMD
high fidelity analog preamplifier attenuation
Thanks to its 24K gold plated CMC connectors with PTFE insulation as well as pure silver wires, Hattor Audio passive preamplifier can compete with the best high-end devices available on the market.
The attenuation stage is equipped with constant impedance inputs and high-precision Vishay SMD resistors, the 64 positions of which have been individually tested before being mounted on solid gold tracks.
Each mono passive attenuator has its own insulated aluminum shield to guarantee optimal channel separation and lowest crosstalk.
Sound-correction purists will enjoy the fact that each potentiometer is in fact independant; allowing the left and right channel to be controlled separately - or on the contrary - to be coupled with a single level / channel.
Its flexibility of operation, its output, its internal design, quality components make the impeccable Audio Hattor a high-performance device for the most demanding ears.
Remote control motorized passive preamp volume
Infrared remote control
The unit comes with a matching remote for a comfortable and easy remote control.
TypeDouble potentiometers passive attenuator
Impedance10K
Sources2 Balanced RCA inputs.
3 balanced XLR Inputs
2 balanced XLR outputs.
2 unbalanced RCA outputs
Remote controlYes
Displaymatrix of LEDs.
FinishTotal Black
Dimensions290 x 263 x 86 mm
Weight4.2kg
Delivered withAC Adapter (5V 600mA)
IR Remote (Black & Silver).
InputXLR
ClassN/A
Remote ControlYes
Préampli Hattor passif
5 étoiles pour sa transparence , ses timbres et sa dynamique !
Il m'a apporté tous les petits détails qui font la scène devant vous !
C'est fluide , les instruments gagnent en matière .
Bravo et merci à l'équipe pas avare de conseils !
This review has been posted for HATTOR AUDIO THE BIG Balanced Passive Preamplifier Vishay SMD Black
