HATTOR AUDIO THE BIG Unbalanced Passive Preamplifier Vishay SMD Black / Silver
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction refinement. Both passive preamplifier and selectors for 5 sources and 4 outputs, this device with its aluminium and black carbon finish will convince. It is equipped with very high quality components assembled by hand with the greatest care.
By buying this product you get 94 loyalty points
Reference : 10710
949,00 €tax incl.
790,83 € tax excl.
HATTOR AUDIO the big
Préamplificateur Passif Haute Fidélité Asymétrique Pilotable
HATTOR AUDIO Préamplificateur Passif Haute Fidélité Asymétrique Pilotable
In addition to its magnificent realization, all the conditions are met to guarantee a high level of High Fidelity reproduction. The American origin CMC 24K PTFE gold-plated connector, silver wire wiring, allows the Hattor Audio passive preamplifier to measure itself in terms of resolution against the best High End achievements on the market.
The attenuator part is equipped with high-precision 64-position Vishay SMD resistors individually tested with solid gold tracks and constant impedance inputs. The two totally separate single passive attenuators guarantee very low crosstalk thanks to their machined aluminium shields.
Ultimately refined, the two potentiometers can be dissociated to control the left or right channel separately or inversely couple them with a level difference adjustable per channel. The flexibility of operation, the number of outputs, the internal design, the quality of irreproachable components make the Hattor Audio an essential device.
Product typePassive preamplifier
Attenuator typePassive attenuator with double Shunt potentiometers with 1% switched resistors
Attenuation value10K
Input selectionx5 - Controlled by remote control
Inputs5x Single-ended RCA
Outputs4x Single-ended RCA
DisplayLED matrix
Right and left volumes  dissociable or not-
FinitionBlack, carbon et chrome
Dimensions290 x 263 x 86mm
Weight4.2kg
Package1x Hattor Audio preamplifier
1x Switching power adapter 5V 600mA
1x IR Remote control
ClassN/A
Remote ControlYes
2 reviews
Acheté avec bloc stéréo purifi S400ET, je dois dire que cet ensemble est de très haut niveau musical.
Sont au rendez vous une très belle transparence, dynamique, punch,justesse et musicalité assez édifiante. On lève un voile sur le message, qui donne l'impression d'une pureté fabuleuse.
Petit bémol, chez moi cet ensemble tellement pur, souffre immédiatement de la qualité du secteur, qui se matérialise par une dynamique très atténuée, ainsi que les aigus.
À noter qu'il convient également de trouver le sens secteur de chaque appareil.
Une fois cela, si votre système est à la hauteur, c'est sublime.
Christian
This review has been posted for HATTOR AUDIO THE BIG Unbalanced Passive Preamplifier Vishay SMD Black / Silver
Royal
Une petite merveille musicale. Magnifique avec mon Job 225.
This passive remote-controllable preamplifier with dual attenuators with 1% accuracy SMD resistors offers the latest in sound reproduction...
