HATTOR TUBE ACTIVE STAGE Tube Gain / Buffer Stage ECC82 +9dB
The Hattor Audio Tube Active Stage is a very high quality gain/buffer stage. It has been thought and designed mainly to be associated with the passive preamplifiers of the brand. However, it can also be used with other passive preamplifiers.
By buying this product you get 199 loyalty points
Reference : 17372
1 990,00 €tax incl.
1 658,33 € tax excl.
Hattor Tube Active Stage
Hattor Tube Active Stage Étage de Gain / Buffer à Tubes ECC82 +9dB
This model embeds exclusively high-performance components. We can find ECC82 (12AU7/5963) tubes from JAN Philips, MIFLEX and RIFA capacitors, a SIZEI toroidal transformer or AMRG resistors. The Hattor Audio Tube Active Stage has an output impedance low enough to power two power amplifiers.
Product typeActive gain / buffer stage
Inputs1* Balanced stereo XLR
1* Single-ended stereo RCA
Outputs2* Balanced stereo XLR
2* Single-ended stereo RCA
Gain+9dB
SNR105dB
Distortion (THD, IMD)0.01%
Input impedance5kΩ
Output impedance200Ω
Dimensions (L*P*H)370*290*90mm
Weight~4.8kg
Housing materialAluminum
InputXLR
ClassTube amp
Remote ControlN/A
The Hattor Audio Tube Active Stage is a very high quality gain/buffer stage. It has been thought and designed mainly to be associated with the...
