HOLO AUDIO SERENE Discrete Balanced Preamplifier
Holo Audio offers with the Serene a fully balanced, high performance preamplifier based on a discrete component design. The left and right channels are separated, each with independent amplifier modules. It also benefits from a two-stage buffer and amplifier section. The preamplifier concentrates largely on its attenuation performance and ensures excellent low level reproduction.
By buying this product you get 316 loyalty points
Reference : 16293
3 169,00 €tax incl.
2 640,83 € tax excl.
Shipping date: 29-04-2025.
Holo Audio Serene
Holo Audio Serene Préamplificateur Symétrique Discret
Its discrete amplifier modules focus on the characteristics of the transistors themselves, allowing them to overcome the usual limitations of transistors. A design that promotes a delicate and transparent sound reproduction, combining the advantages of both transistor and tube systems. Moreover, the use of a large number of transistors favors the linearity of the preamplifier.
For its power supply stage, the Holo Audio Serene has a completely independent structure, capable of providing the audio circuits with a perfectly clean and stable electrical signal.
For volume control, the Serene uses an 84dB analog step system with a two channel matching margin of only ±0.1dB. Each step corresponds to 1dB over a range of -78dB to +6dB. It thus offers a very low noise level and can be precisely controlled.
On the connectic side, the Holo Audio Serene provides two XLR inputs and three RCA inputs. On the output side, there are two XLR outputs and one RCA output that can work simultaneously. Moreover, the XLR1 output can power supply a headphone by developing a power of 3W under 32Ω (the preamplifier does not however have a headphone protection circuit).
This product works with both 220V AC and 110V AC supply voltage. By default, however, it is set for use with 220V AC. For use on 110V AC, it is necessary to set the device to this supply voltage via an internal switch before use and connection.
Product typePreamplifier
Inputs2x Balanced XLR
3x Single-ended RCA
Outputs2x Balanced XLR
1x Single-ended RCA
Maximum amplitude of the inputsRCA : 12Vpp
XLR : 24Vpp
Input impedanceRCA : 6.8kΩ
XLR : 13.6kΩ
Outputs max amplitudeRCA : 8.5Vrmms
XLR : 17Vrms
Output impedanceRCA : 20Ω
XLR1 : 3Ω
XLR2 : 40Ω
Supply voltage220-230VAC 50/60Hz - Fuse type 2A SB 5x20mm
Consumption30W
Case materialAluminum
Total dimensions430 x 300 x 67mm
Weight9.5kg
InputXLR
ColorCopper
ClassClass A / AB
Remote ControlYes
Préamplificateur très haut de gamme
Voilà une semaine que j'ai reçu le préampli Serene et après une cinquantaine d'heures de rôdage il a amélioré considérablement le son de tout ce qui y est connecté. Arrière-plan plus dynamique, plus détaillé et plus silencieux.  D'une part, j'entends des passages au début et à la fin de cds que je n'avais jamais entendus auparavant. Tout cela ajoute au réalisme de la performance.
C'est comme si un voile avait été levé sur mon système. Des détails et une clarté incroyables, et juste le sentiment que rien ne change le signal. On a également l'impression qu'il n'y a aucun bruit de fond. C'est un préampli très haut de gamme.
Accompagné du Dac Spring 3 Level 2 de la même marque le son est excellent : tonalité bien équilibrée, scène sonore très élargie, une grande profondeur . La combinaison SERENE-SPRING 3 forment un ensemble homogène très haut de gamme. Et dernier point des 2 produits Holo Audio, le préampli SERENEet le dac SPRING 3 LEVEL 2 la construction, l’ingénierie et la fabrication sont exceptionnelles. Les détails en cuivre, les pieds, et surtout le contrôle du volume ('du gain') est magnifique, réglable avec une précision d'horloger.
Merci à toute l'équipe d'Audiophonics pour sa réactivité, ses conseils, sa rapidité pour la réception des produits et l'envoi de ceux-ci.
Un grand merci à David Aubert pour tous les conseils qu'il m'a donné pour me diriger vers un système très haut de gamme qui va continuer à s'amélioré.
This review has been posted for HOLO AUDIO SERENE Discrete Balanced Preamplifier
Holo Audio offers with the Serene a fully balanced, high performance preamplifier based on a discrete component design. The left and right channels...
