KHOZMO ACOUSTIC Passive Preamplifier / 10k Source Selector
this passive attenuator uses a precision resistor that is connected in parallel with a 1% SMD mechanical resistance switch. this resistor is connected to the potentiometer, which, depending on its position, more or less connects the output to ground and thus varies the volume.
By buying this product you get 59 loyalty points
Reference : 8684
599,00 €tax incl.
499,17 € tax excl.
Khozmo Acoustic Preamplifier
Passive preamplifier / Input selector 10k
Khozmo Acoustic Préamplificateur Passif / Sélecteur de Source 10k
It is therefore the resistance R-In that determines the minimum input impedance when the potentiometer is in position 0. Both passive preamplifier and source selector, this device with its Aluminium and wood finish will convince. It is equipped with very high quality components assembled by hand with the greatest care. In addition to its magnificent design, this volume controller features the latest technology in this field.
Product typePassive preamplifier and source selector
Selector modelLorlin UK CK1062
Housing materialAluminium and woof
AttenuatorStereo, 10K (Resistances CMS 1%)
Inputs3x Stereo RCA
Sorties2x Stereo RCA
Dimensions240 x 210 x 60mm
Weight2.8kg
ColorBrown
ColorSilver
ClassN/A
Top produit (aucune coloration ni perte, finition exemplaire)
Je cherchais un preampli passif de qualité pour relier deux sources à mon ampli de puissance. Celui-ci répondait à mes besoins. La finition est à la hauteur du prix. Aucune coloration ni perte audible. L'atténuateur est un plus (mais je ne l'utilise pas). Son seul défaut: le long, tres long délais d'appro (5-6 semaines dans mon cas, très loin des 2-3 semaines annoncées)
This review has been posted for KHOZMO ACOUSTIC Passive Preamplifier / 10k Source Selector
this passive attenuator uses a precision resistor that is connected in parallel with a 1% SMD mechanical resistance switch. this resistor is...
