KHOZMO ACOUSTIC Volume Controller / Source Selector 10K + Remote Control Silver
Both passive preamplifier and source selector, this aluminum and wood finish unit will surely convince you. It is equipped with very high quality components assembled by hand with the utmost care. In addition to its magnificent realization, this volume controller has the best technical features.
By buying this product you get 62 loyalty points
Reference : 15020
629,00 €tax incl.
524,17 € tax excl.
Khozmo Acoustic
Khozmo Acoustic Contrôleur de volume / Sélecteur de source 10k + Télécommande
This Khozmo Acoustic passive attenuator uses a resistor connected in parallel with a 1% SMD resistor mechanical switch. This resistor is connected to the potentiometer, which, depending on its position, more or less connects the output to ground and thus varies the volume. It is therefore the R-In resistor that conditions the minimum input impedance, when the potentiometer is on position 0.
Product typeVolume controller
Input selector
Inputs3x Stereo RCA
Sorties2x Stereo RCA
DisplayLED Matrix
Attenuating resistor10K
Power supply15V DC 1.5A (power supply included)
Housing materialAluminum and wood
Dimensions240 x 210 x 60mm
Weight2.8kg
Package1x Khozmo Acoustic volume controller / input selector
1x Power supply
1x IR Remote control
ColorSilver
ClassN/A
Remote ControlYes
Both passive preamplifier and source selector, this aluminum and wood finish unit will surely convince you. It is equipped with very high quality...
