Preamplifier with Tone Control OPA LM4562
In addition to a volume control by rotary potentiometer, this preamplifier offers a triple tone control. Its possibilities are based on a series of components that allow to offer a high-performance device at a reasonable price.
Reference : 14296
79,00 €tax incl.
65,83 € tax excl.
PREAMPLIFIER LM4562
Stereo preamplifier with tone control
audiophonics préamplificateur
In addition to a volume control by rotary potentiometer, this preamplifier offers a triple tone control. Its possibilities are based on a clever selection of components allowing the device to offer a high-performance whileremaining low-priced.
Very easy to use, it has an input and an output on gold-plated stereo RCA connector.  It is controlled using four potentiometers (bass, medium, treble, general volume) as well as an on / off selector.
Tone control
The main feature of this preamplifier is to offer a triple tone control. It is capable of independently adjusting the bass, mid and treble as needed. You can therefore adapt the sound reproduction according to your installation and the desired listening, or correct the potential sound gaps in your audio system.
When on position zero, the trebble button has a function to bypass the tone circuit.
Audiophonics PRE-TC10 préamplificateur contrôle de volume
Audiophonics PRE-TC10 préamplificateur contrôle de tonalité
Quality audio components
This preamplifier uses quality components to offer very good audio performance. It includes a regulated linear power supply with its own toroidal transformer, high speed rectifier bridge and filtering by ELNA capacitor. The audio circuit uses a switching relay.
Two LM4562 operational amplifiers mounted on DIP-8 support (removable). Both of them can be replaced according to the user's taste or the specificity of the whole sound installation in order to change the sound flavor.
Tone ControlBass
Medium
High
OPA (on DIP-8 support)2x LM4562
Regulators1x LM7812
Relay1x RY12W-K
InputRCA Stereo
OutputRCA Stereo
Power supplyVia IEC (câble non fourni) 220V AC.
Dimensions206x 190 x 50mm
Weight1,300kg
Housing100% Aluminum
Silver
ColorSilver
Compact et efficace
Tout juste reçu et branché entre un DAC et un ampli Heed pour avoir une possibilité de réglage des basses et aigus. A l’air de bien faire le job sans trop dénaturer la signature sonore. L’appareil a l’air bien construit mais il chauffe aussi pas mal. A voir dans le temps.
This review has been posted for Preamplifier with Tone Control OPA LM4562
In addition to a volume control by rotary potentiometer, this preamplifier offers a triple tone control. Its possibilities are based on a series of...
