SUCA AUDIO TUBE-T5C Tube Preamplifier 2x 61N Bluetooth 5.0 aptX LL USB 24bit 192kHz
-20%
This Suca Audio Tube-T5C tube preamplifier is compact, affordable and efficient. It embeds two 61N tubes, allowing it to reveal a musical and round sound reproduction. The Tube-T5C is equipped with modern connectivity, including USB-B and Bluetooth 5.0 reception.
Reduced price!
Reference : 16924
Limited special offer
99,00 €tax incl.
-20%
79,20 €tax incl.
66,00 € tax excl.
Suca Audio Tube-T5C
Préamplificateur à Tubes 2x 61N Bluetooth 5.0 aptX LL USB 24bit 192kHz
Suca Audio Tube-T5C Préamplificateur à Tubes 2x 61N Bluetooth 5.0 aptX LL USB 24bit 192kHz
This Suca Audio Tube-T5C tube preamplifier is compact, affordable and efficient. It embeds two 61N tubes, allowing it to reveal a musical and round sound reproduction. The Tube-T5C is equipped with modern connectivity, including USB-B and Bluetooth 5.0 reception, in addition to RCA, making it possible to connect the Tube-T5C to a computer or to broadcast your music wirelessly from a smartphone or a tablet for example. The USB input uses a CM4462 interface, the Bluetooth reception a Qualcomm QCC3008 chip. On the output side, we find stereo RCA but also a 3.5mm headphone output on the front. Moreover, for greater versatility, the Tube-T5C has a tone control that allows you to adjust the level of bass and treble depending on your listening style and your audio system.
Product typeTube preamplifier
Tubes2*6N1
InputsBluetooth 5.0
USB-B
1x Stereo RCA
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
Frequency response20Hz-20kHz (±3dB)
Bluetooth chipQCC3008
USB InterfaceCM4462
OPANE5532P
SNR≥ 110dB
THD0.02%
Supported samplinbg rates (USB)PCM jusqu'à 24bit 192kHz
Recommended headphone impedance16-300Ω
Headphone output power150mW @ 32Ω
Input sensitivity0.775V
RCA output level1.4Vrms
Bass/treble gain setting±6dB
Geenral
Dimensions133*128*33mm
Weight480g
OutputJack 6.35mm
ClassTube amp
This Suca Audio Tube-T5C tube preamplifier is compact, affordable and efficient. It embeds two 61N tubes, allowing it to reveal a musical and round...
