TONEWINNER AD-1PRE+ Preamplifier Black
The Tonewinner AD-1PRE+ is a versatile preamplifier that offers a number of interesting features. In fact, it incorporates quality components such as an ES9038 DAC chip combined with two optical inputs, a CT7601PR USB interface, as well as a combination of no less than 9 AOPs (5x OPA1612, 4x OPA1632, 1x OPA1642) and a MUSES72323 volume controller. These components enable it to decode high-resolution streams up to PCM 32bit 768kHz and DSD up to DSD512, delivering a warm final sound with low noise and distortion over a wide dynamic range
By buying this product you get 149 loyalty points
Reference : 19977
1 490,00 €tax incl.
1 241,67 € tax excl.
Shipping date: 22-04-2025.
Tonewinner AD-1PRE+ Preamplifier Class A/B DAC ES9038 32bits 768kHz DSD512 Black
Photo of Tonewinner AD-1PRE+ preamplifier
The Tonewinner AD-1PRE+ is a versatile preamplifier that offers a number of interesting features. In fact, it integrates quality components such as an ES9038 DAC chip combined with two optical inputs, a CT7601PR USB interface, as well as a combination of no less than 9 AOPs (5x OPA1612, 4x OPA1632, 1x OPA1642) and a MUSES72323 volume controller. These components enable it to decode high-resolution streams up to PCM 32bit 768kHz and DSD up to DSD512, delivering a warm final sound with low noise and distortion over a wide dynamic range. When it comes to connectivity, the Tonewinner AD-1PRE+ preamplifier is also extremely complete. Inputs include 4 single-ended RCA inputs, including two phono inputs (for MM and MC cells), one balanced XLR input, two coaxial SPDIF inputs, two Toslink optical inputs and one USB-B input. Outputs include 2 RCA line outputs and 1 XLR balanced line output. Finally, a trigger connector and remote control enhance the user experience.
Tonewinner AD-1PRE+ highlights
Tonewinner AD-1PRE+: an audiophile amplification stage
As the ToneWinner AD-1PRE+ is above all a Class A/B preamplifier, the brand has chosen audiophile components for its amplification stage. There are 5 AOP OPA1612, 4 AOP OPA1632 and 1 AOP OPA1642. These components deliver low-noise, low-distortion sound, for a pure, transparent signal at the AD-1PRE+'s outputs.
Photo des AOP du préamplificateur casque AD-1PRE+
Photo de la puce DAC ES9038 PRO et de l'interface USB CT7601PR du préamplificateur Tonewinner AD-1PRE+
Tonewinner AD-1PRE+: ES9038 DAC and CT7601PR USB interface
The AD-1PRE+'s optical and digital input interface incorporates an ESS Technology ES9038 32-bit DAC chip and USB interface. This enables this preamplifier to support high-resolution PCM 32bit 768kHz, DSD DoP256 and native DSD streams up to DSD512. In addition, it supports numerous formats such as SACD, ISO, DST and DFF. These features allow you to make the most of your music library, and to link a wide range of devices to the AD-1PRE+, from CD/SACD players to network players.
Tonewinner AD-1PRE+: Phono-compatible inputs
This preamplifier features two Phono-compatible RCA inputs, one MM-cell-compatible input and one MC-cell-compatible input. A very useful feature for fans of 33 rpm and 45 rpm records, who will be able to use the AD-1PRE+ directly with their turntable and enjoy their vinyl collection with a high-end Hi-Fi system.
Photo des entrées phono du préamplificateur Tonewinner AD-1PRE+
Tonewinner AD-1PRE+ preamplifier overview
Connection diagram of the Tonewinner AD-1PRE+ preamplifier
12x RCA stereo line outputs
2XLR balanced line output
32x RCA stereo inputs: MC phono compatible / MM phono compatible
42x stereo RCA inputs (CD, AUX)
5Balanced XLR input
62x SPDIF Coaxial inputs / 2x Toslink optical inputs
7Trigger
8USB-B input
9GND
10IEC power supply
Product typePreamplifier / DAC
Amplification classA/B
DAC chipES9038
OPA5x OPA1612
4x OPA1632
1x OPA1642
Volume controlMUSES72323
Inputs4x Single-ended RCA stereo (Phono MM, Phono MC, CD, AUX)
1x Balanced XLR stereo
2x Coaxial
2x Toslink Optical
1x USB-B
Outputs2x Single-ended RCA stereo
Supported sample ratesUSB: PCM 32bit 768kHz, DSD DoP256, native DSD512
Optical / Coaxial: 24bit 192kHz, DSD DoP64
Supported audio formatsSACD, ALAC, APE, DIFF, DSF, FLAC, OGG, WAV, AAC, MP3, WMA
Nominal input impedance20 kΩ (analog inputs)
THD≤ 0.0035% (1kHz)
SNR≥ 110dB (A-weighted, direct analog)
Frequency response10Hz-180kHz (+1/-3dB, direct analog)
Crosstalk≥ 102dB (1kHz, analog)
Alimentation110V-115V AC 60Hz, 220V-230V AC 50Hz
Dimensions444 × 106 × 424mm
Net weight9.7kg
Package1x Tonewinner AD-1PRE+ preamplifier
1x Remote control
1x Power cable
InputXLR
ClassClass A / AB
Remote ControlYes
TONEWINNER AD-1PRE+ Preamplifier Class AB DAC ES9038 32bits 768kHz DSD512 Black
The Tonewinner AD-1PRE+ is a versatile preamplifier that offers a number of interesting features. In fact, it incorporates quality components such...
