Transformer for PCB UI 30/10,5 2x9V 6VA
This molded transformer is particularly suitable for PCB integration. It will allow you to feed small systems properly.
Reference : 14498
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 25-04-2025.
Encapsulated Transformer
UI 30/10,5 2x9V 0.33A 6VA
transformer
This encapsulated transformer is ideal for PCB mounting. It will allow you to provide your system with quality food, offering a two-compartment internal design.
Power6VA
Input voltage2x115V / 1x130V
Frequency50/60Hz
Output voltage2x9V 0.333A
Dimensions53 x 44 x 22mm
Possible assemblies
Caution: for 230V installation it is absolutely necessary to connect the 115V pins.
Schema 1
Input 230V / Output 2x9V
Schema 2
Input 230V / Output 1x9V
Schema 3
Input 115V / Output 2x9V
Schema 4
Input 115V / Output 1x9V
ColorBlue
Primary voltage (V)2x 115.0
Primary voltage (V)230.0
Secondary voltage (V)9.0
Power (VA)6.0
