Transformer for PCB UI 30/8 2x12V 0,42A 10VA
This molded transformer is particularly suitable for PCB integration. It will allow you to supply small systems properly.
Reference : 12652
9,90 €tax incl.
8,25 € tax excl.
Encapsulated Transformer
UI 30/8 2x12V 0.42A 10VA
transformateur
This encapsulated transformer is ideal for PCB mounting. It will allow you to provide your system with quality power supply, offering a two-compartment internal design.
Power10VA
Input voltage2x115V / 1x230V
Frequency50/60Hz
Output voltage2x12V 0.42A
Dimensions53 x 45 x 29mm
Possible assemblies
Caution: for 230V installation it is absolutely necessary to connect the 115V pins.
Schema 1
Input 230V / Output 2x12V
Schema 2
Input 230V / Output 1x12V
Schema 3
Input 115V / Output 2x12V
Schema 4
Input 115V / Output 1x12V
Primary voltage (V)2x 115.0
Primary voltage (V)230.0
Secondary voltage (V)12.0
Power (VA)10.0
