Pack 2x Topping B100 Amplifier + Topping E70 Velvet DAC + Topping TCX1 XLR Cables 25cm + Dual Trigger Cable Silver
We offer you a Topping product pack consisting of two B100 amplifiers, a Topping E70 Velvet DAC, a pair of TCX1 modulation cables and a double trigger cable. This pack will enable you to enjoy exceptional listening quality thanks to a dual-mono HiFi system.
By buying this product you get 97 loyalty points
Reference : 19837
979,00 €tax incl.
815,83 € tax excl.
Pack content
Pack Topping 2x Topping B100 + Topping E70 Velvet + Topping TCX1 25cm + Dual trigger cable Silver
Topping pack picture
2x Topping B100: Mono Power Amplifier 100W 4 ohm Silver
The Topping B100 mono power amplifier, little brother of the B200, is a state-of-the-art amplifier in terms of performance. It uses Topping's proprietary amplifier module to deliver 100W of power at 4 ohms, while maintaining a THD+N < 1% and a DNR of 151dB. Ultra high-performance, the B100 is the amplifier of choice for setting up a dual-mono system for anyone looking for a nice reserve of power and uncompromising audio quality. On the interface side, there's a balanced TRS 6.35mm/XLR combo input and an RCA input, while the output is via speaker terminals. A 12V trigger also lets you pair the B100 with a variety of devices for quick and easy power-up.
View complete product page of Topping B100 Topping B100x2
Topping E70 Velvet: DAC AK4499EX XMOS XU316 Bluetooth 5.1 aptX Adaptive LDAC 32bit 768kHz DSD512 Silver
With the E70 VelvetTopping offers a new version of the excellent E70 DAC featuring the new AK4499EX high-end digital-to-analog conversion chip from AKM. For the rest, it takes the excellent technical basis of its elder brother, combining a careful design and high-end components for exceptional sound performance with smart and practical features, such as Bluetooth, a 12V trigger or an adaptable output level
View complete product page of Topping E70 Velvet Topping E70 Velvet
Topping TCX1: XLR Interconnect Cables 25cm (Pair)
TCX1 cables from Topping are high quality XLR male/female cables. They incorporate 6N Copper and Silver plated 6N Copper conductors for perfect signal transmission. Each conductor has a cross section of 0.533mm² (19AWG). The contacts of the connectors are gold plated to maintain excellent conductivity while ensuring high resistance to oxidation. Each cable has a beautiful and robust black and red braided nylon sheath.
V iew complete product page of Topping TCX1 Topping TCX1
Topping Dual Trigger cable: Jack 3.5mm Male to 2x Jack 3.5mm Male cable
This Topping cable is a double trigger cable, specifically designed for use with the brand's B100/B200 mono amplifiers. It consists of a 3.5mm stereo jack connector to 2 3.5mm stereo jack connectors. Perfect for pairing the E70 or E70 Velvet DAC with two B100s, for example. With a length of 2m, it allows you to position your devices freely in your room.
View complete product page of topping trigger cable Câble double trigger
Product type2x Mono amplifiers + DAC + Interconnect cables + Trigger cable
Package content2x Topping B100
1x Topping E70 Velvet
1x Topping TCX1
1x Topping dual trigger cable
Topping B100 specifications
Product typePower amplifier
ChannelMono
Inputs1x Balanced TRS 6.35mm/XLR combo jack input
1x RCA input
OutputSpeaker terminal block
Trigger 12V
Topping B100 measurement
Input typeBalancedUnbalanced
THD+N @ 1kHz (A-wt)<0.00008% @ 4Ω 5W
<0.00008% @ 8Ω 5W
<0.00008% @ 4Ω 5W
<0.00008% @ 8Ω 5W
THD @ 20-20kHz (90kBW)<0.00007% @ 4Ω 5W
<0.00007% @ 8Ω 5W
<0.00007% @ 4Ω 5W
<0.00007% @ 8Ω 5W
SNR (A-wt)151dB149dB
Dynamic range151dB149dB
Frequency response20Hz-40kHz (±0.1dB)
10Hz-100kHz (±0.5dB)
20Hz-40kHz (±0.1dB)
Output level56Vpp @ 4Ω
66Vpp @ 8Ω
56Vpp @ 4Ω
66Vpp @ 8Ω
Noise level measured by AP
(A-wt)
<0.7uVrms @ G=L
<1.2uVrms @ G=M
<2.6uVrms @ G=H
<0.9uVrms @ G=L
<2.3uVrms @ G=M
<6.2uVrms @ G=H
Actual noise level<0.3uVrms @ G=L
<1uVrms @ G=M
<2.4uVrms @ G=H
<0.7uVrms @ G=L
<2.2uVrms @ G=M
<6.2uVrms @ G=H
Input sensitivity26.6Vrms @ G=L
8.6Vrms @ G=M
3Vrms @ G=H
13.3Vrms @ G=L
4.3Vrms @ G=M
1.5Vrms @ G=H
Gain0dB @ G=L
10.4dB @ G=M
19.9dB @ G=H
6dB @ G=L
16.4dB @ G=M
25.9dB @ G=H
Output impedance<5mΩ<5mΩ
Input impedance20kΩ5kΩ
Output power100W @ 4Ω THD+N<1%
83W @ 8Ω THD+N<10%
70W @ 8Ω THD+N<1%
100W @ 4Ω THD+N<1%
83W @ 8Ω THD+N<10%
70W @ 8Ω THD+N<1%
Load impedance≥4Ω≥4Ω
Power supply38V DC 4A
Dimensions200x138x40mm
ColorSilver
Package1x Topping B100 mono amplifier
1x AC adapter and power cable
Topping E70 Velvet specifications
Product typeDAC
InputsBluetooth 5.1
1x USB-B
1x Coaxial
1x Optical Toslink
1x Balanced stereo XLR
DAC chipAKM AK4499EX
Bluetooth receptionQCC5125
USB interfaceXMOS XU316
Supported Bluetooth codecsAAC
SBC
aptX
aptX HD
ptX LL
aptX Adaptive
LDAC
Supported sampling ratesUSB : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Measurements
DAC E70 Velvet parameters (line out / USB input @ 96kHz)
RCAXLR
THD+N (A-Weighted)< 0.00008% @ 1kHz< 0.00006% @ 1kHz
THD @ 90kBw (Non-Weighted)< 0.0002% @ 20Hz-20kHz< 0.0002% @ 20Hz-20kHz
SNR (A-Weighted)125dB131dB
Dynamic range @ 1kHz, A-Weighted125dB131dB
Frequency response20Hz-40kHz (±0.3dB)
20Hz-40kHz (±1.0dB)
20Hz-40kHz (±0.2dB)
20Hz-40kHz (±0.8dB)
Output level2.1Vrms @ 0dBFS (Mode 4V)
2.5Vrms @ 0dBFS (Mode 5V)
4.2Vrms @ 0dBFS (Mode 4V)
Noise (A-Weighted)< 1.3µVrms< 1.3µVrms
Channel crosstalk-130dB @ 1kHz-143dB à 1kHz
Channel balance0.3dB0.3dB
Output impedance50Ω100Ω
ColorSilver
Dimensions (L*P*H)200*138*44mm
Package1x Topping E70
1x Remote control
1x USB cable
1x Power cable
1x Bluetooth antenna
Topping TCX1 xlr cable specifications
Product typeXLR Cables
Connectors1x Male XLR 3 poles
1x Female XLR 3 poles
Length25cm
Cable overall diameterØ8mm
Conductors materialCopper
Silver plated Copper
Conductors section0.533mm² (19AWG)
Connectors contacts platingGold
Covering sheathBraided Nylon
ColorBlack and red
QuantitySold by pair (1 cable with red rings, 1 cable with black rings)
Topping Dual trigger Specifications
Product typeDual trigger cable
Length2m
Connectors1x 3.5mm stereo male jack
2x 3.5mm stereo male jacks
Package1x Topping dual trigger cable
We offer you a Topping product pack consisting of two B100 amplifiers, a Topping E70 Velvet DAC, a pair of TCX1 modulation cables and a double...
